balancer ?
Old Aug 7, 2007 | 03:29 PM
zd68's Avatar
Default balancer ?
I have a ls1 corvette 2000 automatic trans
I install it in my corvette 68 with manual trans (tko 600)
I installed a flywheel fidanza aluminium
is necessary ' it to make balancer the unit (dampers ,crank,flywheel )?
I use mainly my corvette on track
Old Aug 7, 2007 | 04:01 PM
'JustDreamin''s Avatar
Not sure what you're asking.....
Can you restate the question?
'JustDreamin'
Old Aug 7, 2007 | 04:39 PM
zd68's Avatar
the origin of my LS1 is a corvette automatic trans
but i instal the LS1 with a tremec tko 600 in my 68 corvette
my question is : it to make balancer the damper, crank ,flywheel ?
sorry for my bad english , i am french
Old Aug 7, 2007 | 07:48 PM
I'm still not following completely, but here goes....
The LS1 is a neutral balance motor. The flywheel and balancer do not have weights on them. This is different than some motors, like the 400 small block, and the small block Ford.
You shouldn't need a different balancer. The one you have should work, assuming it works with your accessory drive (vette accessories need vette balancer, f-body access use f-body balancer, truck access = truck balancer).
Hopefully that answers your question. Please let us know if it doesn't.
And I won't hold being French against you. Obviously your a car guy with taste for American cars.
'JustDreamin'
Old Aug 7, 2007 | 10:04 PM
Rodder's Avatar
I'm pretty sure I can translate--here goes:
Originally Posted by zd68
I have an LS1 from a 2000 Corvette that had an automatic trans.
I installed it in my '68 Corvette with a manual trans (tko 600)
I installed a Fidanza aluminium flywheel on the LS1.
Is it necessary to balance the entire rotating assembly (harmonic balancer ,crankshaft, flywheel) as a unit?
I mainly use my Corvette for the track.
The short answer is "no", it's not required to balance them as a unit. Each component is balanced individually. However, it's impossible to get the balance completely perfect on anything, and by doing each component seperately, you have the potential to have slight errors on each add up to a larger error for the whole assembly. So if you have the engine disassembled, it is a good idea to get the balance checked as a unit and adjusted as necessary.
Old Aug 8, 2007 | 06:25 AM
Except that the balancer isn't keyed to the crankshaft, its a press fit witha retainer bolt. Since its not keyed, there's no way to establish the balancers position relative to the crank. Only way to do that is to put a key in the crank snout and a keyway in the balancer hub.
In short, don't worry about the balancer.
'JustDreamin'
Old Aug 8, 2007 | 06:34 AM
kcmags's Avatar
The balancer is not a concern..but the clutch assy needs to be zero balanced as a set.
Old Aug 8, 2007 | 05:48 PM
zd68's Avatar
to absorb these small unbalanced , a fluidamper is a good solution ?
my engine is not disassembled
sorry I your sentence does not include/understand
http://corvetteclubfrance.forumactif...-t1474-100.htm
