Is this worth it for mock up?
Old Aug 28, 2007 | 07:11 PM
ponjohn's Avatar
Default Is this worth it for mock up?
Plastic LSx block.
http://www.payr.com/index.htm
john
Old Aug 28, 2007 | 07:34 PM
rao's Avatar
rao
If you have the money then absolutely.
Old Aug 28, 2007 | 07:35 PM
rubrhammer's Avatar
John,
I would say it depends on what you have in your shop to manuver an actual engine with. I use 2x2 legs under my overhead door tracks,a 4"channel across them and lift with a chainfall. A cherry picker would be nice but I don't have enough need for it to warrant it sitting around the rest of the time.
If you are doing just one project it may be hard to justify the expense. If you have friends that may need it also, maybe you could get them to chip in on the cost.
I must say that I wouldn't mind having one for locating the holes on my adaptor plates, but I'll survive without it. That is about the only thing I will need one for.Let us know what you do.
Bob
Old Aug 29, 2007 | 10:19 AM
joelvette's Avatar
i just asked around and found a cracked block, found a empty tranny case too, and used them. it's a lot cheaper
Old Aug 29, 2007 | 01:27 PM
67rsss's Avatar
Not a real heavy engine to work with. You should bea ble to either work with the one you are using, or if you have a lot of fab work ahead, go get a bad block from a junkyard.
Old Aug 30, 2007 | 10:45 AM
Steve VanS's Avatar
Your engine is going to be in and out ten or more times during your swap, especially if you are swapping across platforms like we are: LS1 into BMW 3-series. The foam block is worth every penny. So easy to lift in and out. We used it to fab engine mounts, bolt our headers to it and then build the fwd part of the exhaust system, check for fan & radiator clearance by bolting the water pump to it, etc. You can always sell it on eBay when you are done, and probably get 80-90% of what you paid for it. If so, its cheaper than getting a junk block and then getting rid of that iron when you finish your swap.
Old Aug 30, 2007 | 12:16 PM
sirdoc99's Avatar
I looked into this. The only thing I wish they had was a T56 mock-up also. They didn't have one when I was wanting to buy one.
Old Aug 30, 2007 | 01:34 PM
andrew69_04's Avatar
you will be suprised at how many times u have to put the motor in....then back out jsut becuase theres so many things to look at and you dont want to rig somethin up just to get you by....you want to do it right. I wish i had one for my swap but for the few that i do i wont buy one. They ebay idea would work good I think.
Old Aug 30, 2007 | 05:52 PM
ponjohn's Avatar
I emailed them, they have the t56 mold half done. Thier tool maker quit so they are in the process of replaceing him.
John
Old Aug 30, 2007 | 06:02 PM
sirdoc99's Avatar
Yeah if they get that mold made it would def be worth it. Hell, you could rent it out like people do fender rollers. I know I'd rent it
Old Aug 30, 2007 | 06:21 PM
70 chevelle's Avatar
Post ads wanting to buy a junk block , I scored one off craigslist for 40.00
