ls1 into honda s2000
what rear end are you going to use? a low boost F20 blows the stock rear end apart a lsx would melt it.
Andrew
Andrew
here is some inspiration for ya
:http://www.youtube.com/watch?v=WirkGXYdOus
yeah silvia rear end will work r200 or r230 you can find it here:
http://www.courtesyparts.com/Merchan...de=38420-00001
it makes me so happy to see that motor in that car.
beautiful chassis and now a similarly nice motor but with mega displacement, wow that thing is gonna be incredible on the streets. you may have the first LS1-S2000 when its up and running, thats a great world wide claim, congrats and get it up and running asap!
you might need to make your own headers or you might be able to modify the LS1RX7 headers from hinson or from JTR or modify the mustang BBKs or try the vette headers used on LS1240sx swaps. either way best of luck! lookin good and cant wait to see more progress!
more pics too!
EDIT;
here is the ls1 sound over s2k video
http://videos.streetfire.net/video/E...23CCCB8701.htm
and here is the original, -start watching at the 40 sec mark cause that kid is annoying as hell.lol
http://videos.streetfire.net/video/d...78f042a005.htm
should probably keep this on track so not to fug up this awesome thread!
The shop is called Scotty's muffler. Its down on E I think, like in the down town area. Look them up in the phone book. Real nice guys, and awesome work
what issues did you have with aligning the shifter? my car uses the T56 and we had to move the engine forward to get the shifter in the right spot. you moved your engine back 3.5 inches?
have you mock fitted any headers yet, or are you just going to throw parts at it? i ended up putting a front clip on the car, simply to accommodate the custom headers. at the time, there were no off-shelf headers that came even close to fitting.
i'm using C4 IRS. you'd better be using more than a nissan rearend if you want that setup to last.
what size radiator are you going to use? it doesn't look like you have much room left in there, with the stock radiator core support. are you removing the A/C? are you using the OEM multi-belt accessory setup?
and because this is ls1tech, what mods on the engine?
i'd recommend keeping the ABS. if anything, get a standalone ABS unit.
