what fuel pump
Old Sep 18, 2007 | 09:21 PM
kirtondog23's Avatar
Default what fuel pump
I have an LQ4 and the fuel pump I used in the conversion is rated at 55 - 62 psi. Is this ok or will I be better off going with one that is rated higher and letting the regulator even things out?
Thanks,
Old Sep 18, 2007 | 10:20 PM
Rick Speed's Avatar
Yeah I would get a better pump and regulate it down. Running a pump at full psi like that is just asking for a failure not to mention volume problems.
Old Sep 19, 2007 | 04:09 PM
thanks for the reply.
So what psi range fuel pump would you recommend I go up to?
With the pump I have my fuel pressure at the engine is 55 psi. would this be due to the lower pressure pump or some other issue? The regulator is the gm vette one an is new.
Old Sep 20, 2007 | 10:04 AM
no takers on this one?
Old Sep 20, 2007 | 11:56 AM
1dirtyZ's Avatar
try a walbro ( internal or external) they are rated up to 90 psi.
Old Sep 20, 2007 | 12:02 PM
ryanvv355's Avatar
The Bosch 044 moves a ton of fuel, good setup if you like to build now for future mods.
Old Sep 20, 2007 | 12:25 PM
forcd ind's Avatar
are you guys using any external pumps, or mostly internal
Old Sep 20, 2007 | 01:43 PM
my pump is internal. Do I have to pull the pump from the tank or can I put an external on the outside and forget about the one in the inside of the tank?
I know I might be reaching on this one but I really do not want to pull the tank if I can get around it.
I am thinking about throwing this one on my fuel line
GSL392 255LPH High Pressure Walbro Inline Fuel Pump (Universal)
and hooking up the electrical to it and ignoring the fact that there is a pump in my tank. Is this ok or am I being dumb here.
Thanks
Old Sep 20, 2007 | 06:27 PM
blazerboy72's Avatar
I am using an edelbrock. It is actually a walbro 255 but is sold under the edelbrock name for about $50 less.
Old Sep 24, 2007 | 04:37 PM
Ok so it looks like I should get the Edlebrock version of the Walbro inline fuel pump and hook it into my fuel line, hook up the electrical and forget about the pump in the tank. ( the inline pump will pull fuel through the dormant in tank pump)
is this correct?
Old Sep 25, 2007 | 01:58 AM
1dirtyZ's Avatar
is there any way you can cut an access panel in the body above the sending unit, this would make accessing the pump sooooo much easier!
Old Sep 25, 2007 | 09:01 AM
I could cut a pannel out but the floor area there is not uniform so it would be tricky to get things to look good. The floor in the truck has ridges and is made of fiberglass and wood.
Are you saying that I can't use the walbro to pull fuel through the pump in the tank?
The Walbro website I was on advertised the pump as being useful when the intake pump failed and it was to costly to replace the pump in the tank.
Am I missing something in my case?
Thanks
Old Sep 25, 2007 | 05:36 PM
I replaced my low pressure in tank pump with the walbro 255. If you order the edelbrock 255 it is designed as a replacement for a chevrolet 3500 with there mpi kit. It should be a direct replacement for your pump. here is the link to the pump I used: http://store.summitracing.com/partde...5&autoview=sku
Old Sep 25, 2007 | 06:39 PM
IOwnCalculus's Avatar
The Walbro will definitely suck enough fuel to be used without a lift pump, but I would remove as much of the intank pump as possible and just run it as a straight pickup. It seems like trying to suck through a shut-off pump would be a more of a PITA than it's worth.
Old Sep 26, 2007 | 11:07 AM
Carshopinc.com's Avatar
LS1TECH Sponsor
The walbro 255 worked great in my rx7 conversion, I have them with -6 fittings in stock.
Old Nov 10, 2007 | 07:03 PM
BLWN1's Avatar
^ inline or intank? I plan to sump my tank.... is that Elecs car?
