LS1 Impala SS
Old Jun 5, 2003 | 02:52 PM
SSh's Avatar
SSh
Default LS1 Impala SS
96 Impala SS. I hope to finish in the next month or so. I have about 150 hours into it so far.
Still have Eaton, 4.10s, sandblast & paint rear end, wiring, relocate battery, fuel pump, N20... to do.
LS1 Impala Pics
-ssh
Old Jun 5, 2003 | 11:50 PM
John B's Avatar
Moderator
Default Re: 96 Impala SS
Cool! Will the motor be stock or modified?
Old Jun 6, 2003 | 01:13 AM
99PTA's Avatar
nice pics!!
Old Jun 6, 2003 | 06:41 AM
SSh's Avatar
SSh
It is a 2001 LS1 that had 6k miles on it, so it already has the LS6 intake. I changed the cam, spring, ti retainers, ported the oil pump, change the valley cover to the LS6 version for crank case ventilation and switched to a spec stage II clutch and new flywheel. I also plan on a 100-150 shot, I just have to figure out how to hide a 12lb carbon fiber N20 bottle in the trunk (wife). I also cleaned up and painted while I was at it. I did not have a way to powder coat myself (no oven), so I ground flashing, sandblasted and used epoxy primer with a urethane color coat. My two biggest tasks remaining are rebuilding the rear and finishing the wiring.
Thanks,
Scott
Old Jun 11, 2003 | 08:37 AM
SSh's Avatar
SSh
Updated link. LS1 Impala Pics
Old Nov 28, 2003 | 06:03 PM
Kevin Winstead's Avatar
ttt
Just wondered what the updated status was on the Impala.
Kevin
Old Nov 29, 2003 | 11:22 AM
sercastiK's Avatar
did you have to modify your oil pan to fit the LS1 in the Impy?
Jeremy
Old Nov 30, 2003 | 04:54 PM
64ImpalaSS's Avatar
Hi Scott,
For some reason I can't make your link to your pictures work, is the site down or am I doing something wrong?
thanks,
dave
Old Dec 1, 2003 | 01:12 PM
SSh's Avatar
SSh
Smile
Kevin,
It is on the road. It is my daily driver, so I am driving it about 30 miles a day and have been for the past couple of months. The only problem I have had is the ABS is not working. I did not modify the wiring for the ABS, but did have to change the rear reluctor for the 4.10s. I did change the front brake rotors as well. I used a multimeter to check the sensors yesterday and all appears to be OK. I guess I will have to break down and go to a shop that has a Tech 1 that I can plug in. EFILive can not see the EBCM. I don’t think the EBCM is bad, as it does it’s self test when I hit about 15mph. It pulses the brakes the at the first stop then the ABS light comes on and the ABS system is disabled.
I do have a lot I still want to do including:
- build and install a shift light
- install autometer oil pressure, fuel pressure, voltmeter
- hook up the N20 system with a new NX Maximizer controller
- recaro’s to eliminate 75 – 100 lbs.
- remove sub box (install subs in rear deck) to eliminate another 75 – 100 lbs.
Jeremy,
No, I modified the front cross member instead. I will post detailed pictures on the new site I am working on.
Dave,
I took the site down this weekend. I am install 2003 server on the server setting behind my roadrunner (cablemodem) connection. I am in the process of updating the site as well. I have labeled many of the 500+ pictures I took during this project. I am not sure when I will have time to finish, but I will put up the old site and pictures in the mean time.
I attached some pictures I reduced and combined.
[IMG]Impala_Collection-small-web.gif[IMG]
Old Dec 1, 2003 | 01:24 PM
SSh's Avatar
SSh
You may notice from the pictures that I still have the automatic transmission cooler installed. I re-routed the lines and used it for a power steering cooler.
I have also completed the exhaust. I have a 4" oval side exhaust exiting right before the rear tires now. This reduced the drone so that I can actually use 6 gear now.
I also have a set of forgeline RS 17x11s ordered for the rear. I will be installing a set of Goodyear F1 GS-D3 (275/40 front 315/35 rear) as soon as they get here. I will order a set of forgelines for the front in a couple of months. I really need the rears as I am severly traction limited (even without the N2O) at the moment. The N2O should be much more useful with the new tires.
-ssh
Old Dec 1, 2003 | 01:53 PM
Scott,
Thanks for the update! That's a very nice cruiser.
Kevin
Old Dec 14, 2004 | 12:09 PM
fact9c1's Avatar
did you fab up the motor mounts?
Old Dec 15, 2004 | 10:05 AM
owen v8litew8's Avatar
wow,
awesome project, I'd love to buld my own 6 speed version of yours someday.
this is how they should have come from the factory... no doubt.
congrats on a wicked daily driver, I think you'll be much happier with it lighter, sitting in recaros and rolling on those huge new wheels you bought!
more pics more pics!
Old Dec 17, 2004 | 11:00 AM
BoonesZ's Avatar
thats one hell of a boat nice man nice
Old Dec 20, 2004 | 10:25 PM
Damillio's Avatar
you on Impalassforum.com?
