t-5 transmission
Old Oct 8, 2007 | 03:26 PM
79nova's Avatar
Default t-5 transmission
any body put a t-5 behind a lsx motor?,found that gforcetransmissions has t-5 what hold around 600 hp, looking at it
Old Oct 8, 2007 | 05:51 PM
Oscar Will's Avatar
Maybe a World Class T-5 might hold up but it won't take any abuse. I know Gforce builds some pretty tough units but I'm still skeptical.
Old Oct 8, 2007 | 07:11 PM
bgblockelcamino's Avatar
we tried to use a stock T-5 behind a 6.0. for us it didn't seem like it was worth the hassle. we had it bolted up but do not remember exactly why we didn't use it. in the end it was not worth it.
Old Oct 8, 2007 | 11:52 PM
jfman's Avatar
I hate t5's with a passion.
Old Oct 9, 2007 | 04:30 AM
Hans Grüber's Avatar
Have you ever seen the internals of a T5? The gears are tiny.
To give you an idea, the wet weight of a T5 is ~75 lbs.
In comparison a T56 is over 150 lbs.
To say that the T5 are complete garbage is an understatement, it is easy enough to destroy them behind a stock 305 SBC or 302 Ford, let alone an LS1. Keep in mind that the T5 was engineered in the early 80's for sub 200 hp smog motors.
Sure you can build it up, but it will never be even half a strong as a stock T56and it will not be a matter of if it goes, but rather when.
Also when you consider the cost to upgrade a T5 and adapt it to an LS1 with simply buying a used T56 for ~$1500, it simply does not make an sense to use a T5. Not to mention the cost of replacing the T5 every month.
Old Oct 9, 2007 | 04:35 AM
I hate them as well.
Worst of all are those fools who insist that they know someone using one with some 800hp bigblock or something similarly absurd who abuses it all the time yet never has any problems
Old Oct 9, 2007 | 04:38 AM
But for how long.
Old Oct 9, 2007 | 05:00 AM
jfman's Avatar
It's not just the fact that they are weak but they dont shift well. I have never driven a t5 that shifted well.... grinding and no feel at the shifter
Old Oct 9, 2007 | 06:24 AM
99c5vert's Avatar
heh, I had only heard good things about the GForce T5 trannies. I don't know if their claimed limits for the T5 upgrades are realistic, but they have a good reputation.
It certainly does save alot of weight if it works. My car is 1700 lbs, so saving 75 lbs in the tranny is a big deal.
Old Oct 9, 2007 | 11:59 AM
79nova's Avatar
it will behind 4.8 ,for now stock but later will get hopped up,t56 and tko ihave to cut alot of the floor pans i will not do,that just me
Old Oct 9, 2007 | 02:08 PM
s10_onbagz's Avatar
i want to swap a 5.7 or 6.0 lsx motor into my '89 s10 but the only thing holding me up is the fact i cant afford a tranny. someone has to have info on using a stock gm t5 on an lsx motor. my t5 actually has a truck shifter to so when i go t56 i have to move the shifter hole. i know i saw an old hot rod magazine about swapping lsx's in older cars, and they had listed companies who made adaptors, brackets, mounts and everything to use older trannies.
Old Oct 10, 2007 | 10:14 PM
Rodder's Avatar
is the TKO500 really that much bigger than the T5??
Old Oct 10, 2007 | 10:31 PM
Rodder's Avatar
The stock GM NWC T5 is rated for around 230 ft-lbs I think... It will die. Horribly.
You can get a 5.3 and 4L60E for less than the price of just a 5.7 LS1.
Old Oct 10, 2007 | 10:49 PM
Financially this makes no sense at all.
For the price of the T5 and the parts to adapt it, you could have a T56.
Also consider when you destroy the T5, how much more money you will end up spending.
Old Oct 10, 2007 | 10:51 PM
V8Rumble's Avatar
+1
I've had this discussion before. YES, you can beef up the internals of the T5, but even if you do so (& p!ss away your money, IMHO), the real limiting factor is the case strength - it really doesn't matter if you get kevlar clutches, cryo-treated forks, & gears made from pure billet "unobtanium" if the case itself isn't beefy enough to live behind 350 lb/ft of torque... (And no, the so-called "World Class" T5 isn't noticeably better than the "regular" T5 - it might live behind 5-10% more torque, but not any engine worth mentioning...)
If you can't afford to do better than a T5, then in all honesty, you can't afford to do the swap (I'm quite honestly not trying to be offensive). Save your $$$, save the grief - get a REAL tranny.
Old Oct 10, 2007 | 11:27 PM
It's not just the flimsy case, the gears and everything inside it is much smaller compared to a T56.
I simply don't understand why people use these pieces of junk when there are so many better options that don't cost much more.
Old Oct 11, 2007 | 12:33 PM
Oscar Will's Avatar
My wife has a little roadster with a 239 CI Ford Flathead in it with a T-5.......now THAT is a perfect drive train marriage.
Old Oct 11, 2007 | 01:14 PM
79nova's Avatar
this a pic of 74 nova with tko geting put in, right know i looking for a t-5 to test fit in my car,the 68 to 79 use the same floor pans
Old Oct 11, 2007 | 01:22 PM
79nova's Avatar
a differt pic , that why i wont use tko, but that just me
Old Oct 11, 2007 | 01:37 PM
bczee's Avatar
From the pictures.. it takes about as much cutting of the Trans Tunnel as a T56 ..???
