1997 240sx with LS1
Old Oct 13, 2007 | 11:10 AM
AnDy R's Avatar
hey are you on the zy forum? if so whats up! lol
Old Oct 13, 2007 | 02:45 PM
BLKLS1240SX's Avatar
Originally Posted by 240guy
not sure how similar the s14 and s13 chasis are but im assuming its the same deal on the s13?
Yeah
Old Oct 13, 2007 | 04:23 PM
ranger2339's Avatar
Nice set up bro. See some of ya at the Pro AM..
Old Oct 15, 2007 | 08:32 AM
Yeah same here dude
Old Oct 20, 2007 | 02:24 AM
mikespeed95's Avatar
hey gary, car looks hot!
xat is coming out with a custom greddy sr style oil pan for lsjuan though, i was goign to do it but someone that actually gets off hteir *** and does bad *** stuff (chris tyler from xat) has been doing it. ill be running one on my car probably unless we just modify mine.
i just moved to atlanta btw, with dan and tracy up at batlground now, well have to all go play especially when matt gets his done.
Old Oct 20, 2007 | 09:55 AM
RUTH'LESSDET's Avatar
what motor mounts are you using??
Old Oct 20, 2007 | 04:16 PM
Bigchickenhawk's Avatar
Need more lift on that camshaft.....should see 400 rwhp no problem....450...more like a pipe dream. GOODLUCK....the torque is amazing
Old Oct 20, 2007 | 07:03 PM
okis14's Avatar
i just moved to atlanta btw, with dan and tracy up at batlground now, well have to all go play especially when Matt gets his done.
Cool, I hope the pan comes out good. It could save all of us some headache.
You're inching more and more up this way. Soon you'll be at all of our events and hopefully Matt finishes his. I think he's been a little busy and hasn't touched it in a while and he missed the entire '07 season.
Originally Posted by Bigchickenhawk
Need more lift on that camshaft.....should see 400 rwhp no problem....450...more like a pipe dream. GOODLUCK....the torque is amazing.
I don't think I'll hit 450, maybe 435ish max but I like setting higher goals even if they are slightly out of reach.
Seems like a lot of people are making about 415 with some bolt ons. One guy said he made 440. https://ls1tech.com/forums/showthrea...ght=si5&page=2
This is probably 1 of 6 cams that I'll go through, it all depends on how I like it. I have been eye balling the dynos that Vengeance has been putting out there and they are looking good.
If I break 400, which I should, I'll do my happy dance but I know that the engine should be able to do more.
I'm expecting my dyno chart to look similiar to this with and hopefully with a little more peak numbers.
https://ls1tech.com/forums/attachmen...1&d=1176954446
The engine was just started this week but needs a serious tune. Maybe next week I'll toss up a vid and a dyno chart.
Old Oct 20, 2007 | 07:04 PM
okis14's Avatar
Custom. I don't think there are any available yet, other than Hinsons.
Old Oct 20, 2007 | 07:18 PM
Just curious yeah hinson is the only mount kit you can buy...i dont think xat racing sells a diy kit. Can you post more pics of the mounts if you have any and what was use (i.e corvette mount etc...) Thanx.
Old Oct 21, 2007 | 02:47 PM
okis14's Avatar
It's solid mounts right now. Just some plates and roll bar piping.
Old Oct 22, 2007 | 06:22 PM
  #32
Silverbullet86's Avatar
dont forget to photochop that FMIC out of your sig when your monster is running haha.
good stuff.
Old Oct 22, 2007 | 07:46 PM
  #33
ranger2339's Avatar
Here is my mount. Easy solid mounts.
Old Oct 23, 2007 | 02:11 PM
  #34
nice car looks great!
Old Nov 18, 2007 | 07:52 PM
  #35
okis14's Avatar
Numbers are in! MUHUAHAHAHA!!!!11!
https://ls1tech.com/forums/dynamometer-results-comparisons/817072-pp-stage-2-59cc-heads-si5-cam-m6-fast-nw.html#post8147492
I took it to Summit Point Raceway today and made a few laps with it. All I have to say is "WOW!" Instant response and power. My first run was so ugly that I was a little embaressed. This is when I learned 1st and 2nd gear are useless lol.
My second run had a PS line problem then my third I was mainly using 3rd and 4th gear where I normally 2nd and 3rd. I could have went to 5th if I wanted to push it. I then started having more PS problems so I called it a day.
I think I'm going to change my final gear to use the power more efficiently as I was just wrapping right through the gears.
With the few runs I had I know next season is going to rock.
Old Nov 20, 2007 | 12:01 PM
  #36
owen v8litew8's Avatar
congrats!
isnt the LS1 a ton of fun or what!??!?!
very very cool for you, props for getting it on track so soon.
Old Nov 20, 2007 | 06:30 PM
  #37
240SX GTO's Avatar
Do you feel every bump and vibration with this set-up?
Old Nov 25, 2007 | 07:20 PM
  #38
its just a solid engine mount, not like he welded his shocks and replaced all his bushings with spherical bearings, lol.
gary, accusump. i'm taking it upon myself to spread the word.
if your drifting, and actually keeping your foot in it like a big kid, you need something to keep oil in the pan.
Old Nov 25, 2007 | 08:35 PM
  #39
LS1POWERED240's Avatar
Man Mike so kool...."Keeping your foot on it like a big kid" lol
Old Jan 8, 2008 | 12:02 PM
  #40
okis14's Avatar
Seems good, I think I'll get it. Are you running it?
I just recieved word that the first prototype of the oil pan is done. It lowers my current engine by one inch, has better baffling, has more oil capacity, crossmember doesn't have to be notched, allows easy installation of oil cooler, no modifications of the sway bar needed, very minimal to no modifications to the tunnel (AKA beating the hell out of it), and should fit other applications (350z. More to be added later after verified.)
They are currently redoing my mounts so it'll have bushings and take advantage of the new pan height allowance.
Once I get more specs I post them up. I should have pics too. The tentative plan is to have my car completely finished for the first Nopi event on March 15/16 in AZ but it's going to be tough. I still have new paint, fuel cell, electrical changes, guages, and some misc fabrication left. Hopefully I'll get it painted before the Nopi event.
