PP Stage 2 59cc Heads, SI5 Cam, M6, FAST\NW
I finally had my car dyno'd and ran it at a track (drift) today.
Quick list of mods
Pics:
https://ls1tech.com/forums/conversions-swaps/796647-1997-240sx-ls1.html
http://www.d-rated.com/Photo/Photos.aspx?AlbumID=1
My goal was at least 400hp and a smooth powerband. I thought I would get 415ish due to the cam, heads, and headers.
I am very happy with the power it put out and I'm sure a little more could be squeezed out of it but it's more then enough for my needs. It was only run to 6000rpm...for now.
I thought I would go through several cams until I find the "one" that fits my application best but I think I'll stick with this one. I had a grin across my face all day today while hitting it at the track. It is definately a learning curb coming from my previous 4 banger (5 speed Nissan KA24DE-T with about 300hp) to this.
Results: 440.6hp & 406.2tq
Below image is a photoshop overlay of the above chart. Makes reading it a little easier but it could be off slightly.
Quick list of mods
- SI5 231 237 .589 .595 112 +4 Cam
- Patriot Performance 59cc Stage 2 Heads
- LS6 ported Oil Pump
- LS7 Lifters
- Hooker Headers
- Exedy Hyper Single
- ARP Rod Bolts
- FAST 90mm Intake
- NW 90mm TB
Pics:
Nice results..
Patriot heads are by far the best bang for the buck..
And don't let anyone tell you that your car should rev higher because it makes "X" hp... why make 440 at 7k when you make it at 6k...
Nice combo.. congrats.
By not reving higher, regardless of peak power, he's dropping out of his power band every shift.
We do plan on bumping the RPM up but the RPM alone isn't going to make much difference for me since the gearing is going to have to change to utilize the powerband better.
One of the reasons I dumped my old engine and went with the LS1 is because dropping out the powerband is just going to happen but this motor just gets right back into it. I think I found my favorite engine.
I agree with you but just keep in mind this application is not for drag racing or any timed racing. I'm hesitant to say this but it is for drifting. Even at 3000rpm this engine makes more then enough then what I need.
as someoen who's blown 2 motors drifting due to the awesomeness of the oiling system the ls1 comes with at sustained high rpm theres no need to rev it higher if you dont have to.
but i do reccommend an accusump.
nice #'s gary.
