Look what i just found
Old Oct 29, 2007 | 08:26 PM
Ls2Sonoma's Avatar
Default Look what i just found
my truck popped a fuse the other night, so of course the first thing i do is check my wiring harness by pulling it out and unwrapping it! after that was clean, i decided to check inside the pcm for any signs of a problem...
if you cant see it, heres a better view
Old Oct 30, 2007 | 07:01 AM
Jhankinson's Avatar
Yeah that could def cause a short. How did it happen I wonder..hmm. Hope you can get a new PCM soon...cause I am sure that one is fried now. That sucks.
Old Oct 30, 2007 | 07:10 AM
thunderdan74's Avatar
It might not be. Re seat that lower pin. See if it fixes it. What signals are on those 2 pins?
Old Oct 30, 2007 | 10:24 AM
Schitzo's Avatar
I would have never thought to open up the PCM to check for the problem.
Old Oct 30, 2007 | 08:51 PM
Ls2Sonoma's Avatar
i talked to the guy i bought the pcm from and he had no idea either how it could have happened. theres nothing on the connector side that could have pushed it in. lastly, i drove over 5000km since i had it unplugged... only way it could have moved was due to vibration!
those two lines are battery power and TPS ground, so it blew the fuse right away... it might still be a good pcm
Old Oct 30, 2007 | 09:42 PM
jfman's Avatar
How much are these pcm worth ? Prices vary so much. Some ppl asking 200+ while pthers ask lik 80 ?????
Old Oct 30, 2007 | 09:55 PM
Rick Speed's Avatar
Nice job finding that.. I'd of never guessed to find that
Old Oct 31, 2007 | 10:33 PM
Ls2Sonoma's Avatar
just got it running tonight!
the pcm is still good, yay
LS2 SLonoma
Old Nov 1, 2007 | 07:13 AM
stealth71's Avatar
Very nice.
Old Nov 2, 2007 | 12:06 PM
Remington H.'s Avatar
you can get a pcm from most gm late model vehicle that has the same basic pinout numbers and style of comp, and have it reprogrammed with a different vin to have your engine/trans combo folders pop up for reprogramming. I had a 5.3/4l60e comp and had a new vin flashed in to change it to a 6.0/4l80e when I worked on a swap several years ago.
Remington
Old Nov 3, 2007 | 01:24 PM
Gen3Benz's Avatar
Good to hear the PCM is still good.
Any info/pics of your truck?
