Old Oct 30, 2007 | 10:08 AM
ls1trucker's Avatar
Default 1500
I got a 99 1500 4x4 a/t with a 5.3, and i want to swap with a ls1
Can anyone steer me in the right direction?
jason
thomasje@mcm12.navy.mil
Old Oct 30, 2007 | 11:33 AM
LS1GMCTruck's Avatar
Wink Simple Engine Swap
Just assemble/buy a complete shortblock LS1 and install all your 5.3 accessories on it, and then it's just a simple R & R, using your 5.3 harness/computer as well. This is the easiest of all swaps. Its been brought up before, here on the board. Research, research, research.
Old Oct 30, 2007 | 11:36 AM
Default Oh...By The Way...
Welcome to LS1Tech!
Old Oct 30, 2007 | 12:53 PM
cherryelky305's Avatar
Might also consider just building up the 5.3, people do make decent power with those. just a thought, its only a difference of .4 liters.
Old Oct 30, 2007 | 01:09 PM
bczee's Avatar
Why not get a LQ4/9 short block or with heads.. !
Old Oct 30, 2007 | 01:32 PM
andrew69_04's Avatar
ya idk if i would spend the money for an LS1 when you alrady have a 5.3L....i would consider doing the 6.0 swap as mentioned above
Old Oct 30, 2007 | 03:13 PM
ryanvv355's Avatar
+1 for 6.0 swap.
Old Nov 2, 2007 | 12:36 PM
ls1trucker's Avatar
Default 1500
I take it that a built up long block would work just as well???? what kinda difference is there between intake/injection system between the ls and ls1. And if i was to use a 6.0 longblock, will the 5.3 harness and computer work with that as well?
Old Nov 8, 2007 | 03:09 AM
jfman's Avatar
The ls1 intake manifold is different. It's a lower desing and will not clear the truck water pump. Just use the 5.3 manifold an youll be set.
Yes the 5.3 computer and harness will work with the ls1 and 6.0.
Basicaly the 5.3 and ls1 and 6.0 are the same externaly and are completely interchangeable. You could bolt a 5.3 in a camaro or a vette if you wanted to and vice versa.
The only thing you need from the 6.0 or ls1 is the block and heads. If you use an ls1, you have to install the oil pan from your 5.3 on it IIRC.
