pinouts for gauge cluster?
Old Nov 6, 2007 | 05:55 PM
leonpiper69's Avatar
Default pinouts for gauge cluster?
i searched and cant seem to find a pinout for the gauges 99-02 f-bod. does anyone have them and are the same for v-6 and v-8 gauges? i presume they are the same because i cant think of anyhting that would be diff on the underdash harness.
Old Nov 6, 2007 | 08:54 PM
lt4malibu's Avatar
Pin
Wire Color
Circuit No.
Function
A1-A2
Not Used
A3
PNK
39
Ignition 1 Voltage
A4
Not Used
A5
TAN/WHT
33
Brake Warning Indicator Control
A6-A7
Not Used
A8
BRN/WHT
419
MIL Control
A9
Not Used
A10
ORN
640
Battery Positive Voltage
A11
Not Used
A12
LT BLU
14
Left Turn Signal Lamps Supply Voltage
A12
LT BLU/WHT
1414
Left Front Turn Signal Switch Signal
A13
PPL/WHT
237
Instrument Panel Lamp Control
A14-A16
Not Used
A17
LT GRN
11
Headlamp High Beam Supply Voltage
B1
BRN
9
Park Lamp Supply Voltage
B2
Not Used
B3
GRY
728
Security Indicator Control
B4
Not Used
B5
PPL/WHT
1035
Starter Relay Coil Supply Voltage
B6
GRY
1036
IPC Class 2 Serial Data
B7
ORN/BLK
737
Trunk Lamp Control
B8
DK GRN/WHT
817
VSS Signal
B9
GRY
8
Instrument Panel Lamp Supply Voltage - 1
B10
DK BLU
15
Right Turn Signal Lamps Supply Voltage - Europe, Japan
B10
DK BLU/WHT
1415
Right Front Turn Signal Switch Signal - Domestic, Gulf
B11
BLK
650
Ground
B12-B22
Not Used
B14
TAN
31
Oil Pressure Indicator Control
B15
BLK
650
Ground
B16-B17
Not Used
Old Nov 7, 2007 | 04:43 PM
sweet dude, thank you thank you thank you. BUT.....what is a mil control?
and where it says "headlamp hi beam supply voltage" does that mean it just lights up[ the high beam indicator or does the power have to go through there to go to the hi beams? i hope this doesnt seem dumb, i just dont want to start hooking up wires and fry something because i didnt ask.
and thanks again.
Old Nov 7, 2007 | 09:16 PM
almostfast's Avatar
mil= malfunction indicator light (service engine soon)
Old Nov 8, 2007 | 09:31 AM
lt4malibu's Avatar
"headlamp hibeam supply" is for the hibeam indicator.
if you need the connector pic let me know.
Old Nov 8, 2007 | 01:29 PM
i shoulg be good now. thanks for the help guys. i thought was for the indicator, i just wanted to make sure i was understanding what i was reading. i really appreciate the help guys.
Old Nov 9, 2007 | 12:51 PM
deuce_454's Avatar
awesome info... now how do i figure out what the coresponding inputs are on a C5 dash???
Old Nov 9, 2007 | 02:15 PM
lt4malibu's Avatar
C5:
Pin
Wire Color
Circuit No.
Function
A1
Not Used
A2
LT GRN
11
A3
WHT
103
Headlamp Switch Headlamps On Signal
A4
BLK/WHT
99
Windshield Washer Fluid Level Signal
A5
Not Used
A6
TAN/WHT
33
A7
DK GRN/WHT
817
Vehicle Speed Signal
A8
BLK
150
Ground
A9
Not Used
A10
DK GRN/WHT
357
Oil Temperature Sensor Signal
A11
GRY
1036
A12
Not Used
A13
PNK
139
Ignition 1 Voltage
A14
ORN
1640
A15
LT BLU
14
Left Turn Signal Status Signal
A16
DK BLU
15
Right Turn Signal Status Signal
A17
WHT
121
Engine Speed Signal
B1
Not Used
B2
BLK/WHT
238
Seat Belt Switch Signal -- Driver
B3
Not Used
B4
PPL
333
Brake Fluid Level Sensor Signal
B5
WHT
717
Illuminated Display Signal
B6
GRY/BLK
1458
Instrument Panel Lamp Supply Voltage - 4
B7
Not Used
B8
BLK
470
Low Reference
B9-B10
Not Used
B11
WHT
375
Skip Shift Indicator Control
B12
Not Used
B13
BLK/WHT
851
Ground
B14
Not Used
B15
BLK
150
Ground
B16
BRN/WHT
419
MIL Control
B17
BRN
9
Old Nov 10, 2007 | 12:48 PM
deuce_454's Avatar
wow... you rock! thanks a million
Old Nov 10, 2007 | 01:09 PM
lt4malibu's Avatar
no problem
