Best way to connect the TCC relay to brake pedal..diagram?
Hello ..my first time in here ...wondering whats the best way to connect the tcc wire from the pcm on a 2001 ls1 engine into a brake pedal ? anyone with a diagram ? thanks
MY 1969 CAMARO RS SS PROJECT =X
Re: Best way to connect the TCC relay to brake pedal..diagram?
I used a stoplight switch off a monte carlo with cruise control for my elcamino swap. Hook the brake lights back up like normal and on the other 2 post run your TCC wire and the other side to a ground. Just be sure with a omh meter that when you step on brake to open switch it closes the circuit on TCC wire and sends it to ground.
