LSX oil pans
Old Apr 1, 2010 | 11:25 AM
  #241
69blackwhss's Avatar
Default what oil pan works
hey guys am doin a ls1 out of a 2000 camaro ss and puting it in to a 69 camaro. what oil pan will work for my appt. an ill be using the hooker header motor plates so i can use the hooker headers. thanks for any help guys
jason
Old Apr 6, 2010 | 09:41 PM
  #242
Redrumls's Avatar
Smile
I just ordered gm's new muscle car oil pan for ls conversions. Comes with pick up tube, windage tray, dipstick, bolts & gasket for $150!
Just finished 6.0 swap into my 68 camaro & truck pan sits to low, just look for gm ls oil pans & it will come up.
Old Apr 6, 2010 | 10:16 PM
  #243
marco_chevy's Avatar
truck pan have 8.25 inch... muscle car oil pan have 7.75... same problem : ground clearence....
For early camaro, you need max 6 inch tall maximum.... like moroso, autokraft!!!
good luck.
Old Apr 7, 2010 | 02:19 AM
  #244
Redrumls's Avatar
the truck pan I have is 8.75 in. long so the muscle car pan from gm would really help out!
Old Apr 7, 2010 | 07:02 AM
  #245
1976CamaroGuy's Avatar
I was under the impression that the "muscle car" oil pan was still a little too tall for F-body cars. Someone had mentioned that this set-up was actually a re-branded stock oil pan from a production vehicle...maybe H2?? Someone correct me on this.
I ended up getting a used LS1 camaro oil pan and a set of 1" set back motor mount adapters for my 76 Camaro to get everything to work...plenty of clearance.
Old Apr 7, 2010 | 07:12 AM
  #246
THe muscle car pan will giv you only 1 inch more....!!!!! you really need 6in total, max 6 1/4... i have dropped my car of 2 inch, and whit a 6 inch oil pan, the pan will be at 2 .5 inch from the ground....! 0.75 inch whit the muscle car pan!
Old Apr 7, 2010 | 09:36 AM
  #247
Redrumls's Avatar
I have the truck pan in my camaro right now & it has bout 4" ground clearance & it's a lil lowered. Im going to put the muscle car pan & raise the car back to original, should be fine.
Old Apr 7, 2010 | 10:19 AM
  #248
if you already have 4''... no problem... i will only have 2.5 inch... but i have harder coil spring.
Old Apr 7, 2010 | 12:28 PM
  #249
Redrumls's Avatar
my problem was bad shocks & soft spings, it rubbed a couple of times. I'm going with other pan with good shocks & stiffer spings like yours. 1 more inch would really help, at least that's what she said, hehe..
Old Apr 7, 2010 | 08:36 PM
  #250
3pedals's Avatar
is 4to 4.5Lof oil enough? I have the truck pan on my '07 LY6 and I will be cutting it down too, So I need to know if this is enough oil to run down the dragstrip WFO.
Old Apr 7, 2010 | 08:50 PM
  #251
jasonsnova's Avatar
i know most all super stock drag racers run there engines at bear mininum oil, usually about that amount. on my set up i'm gonna run the oil cooler and i'm gonna run a dual oil filter set up too to add to oil capacity....
stock camaro is only 5.5 qts, most other cars are 5 qts also...
Old Apr 7, 2010 | 08:54 PM
  #252
3pedals's Avatar
racers run lower oil to keep it down and away from the crank, that advantage is gone when the volume of the pan is reduced. I am wondering if the oil pump can or will drain the reduced volume pan, in the 12ish seconds at high rpm, that a run takes.
I question wether a resevoir will help any, as the pickupp has to be covered, to pump oil through the lines, so that added volume is not really available if the oil level gets to low(reduced volume pan) in the first place???
Old Apr 7, 2010 | 09:20 PM
  #253
hope have an anser to this question..... i chek whit water on my pan, and if i cut off 2inch, i will lost 1.8 qts. To the full dip stick line, i enter near 6 qts . After mod, i will have only 4.2 qts + oil filter, oil pump and pickup full, i will have max 5 qts total. About 3.5 - 4 qts over the pickup is enough for never miss oil pressure at high RPM....?
Old Apr 8, 2010 | 04:17 PM
  #254
someone can anser to this technial question ?
Old Apr 8, 2010 | 04:25 PM
  #255
Hotrod406's Avatar
Old school small block pans are 4 qts plus filter so you should be fine. It might not be good for sustained high rpm or road racing though. Keep an eye on that pressure gauge during those times.
Old Apr 17, 2010 | 06:24 PM
  #256
Hotrod406's Avatar
Originally Posted by fafnir
does anyone know if a GTO oil pan will swap onto an L76 out of a G8 if the DoD or AFM was retained?
e.g. there is some sort of pressure bypass valve in the G8 pan, if i swapped in a non DoD pan would that work at all or are there any workarounds?
thanks for the time
_
There are no valves in the oil pan so you will be fine swapping.
Old Apr 17, 2010 | 09:35 PM
  #257
yes... it have a valve in the DOD pan... that have 55psi max pressure...( i think)... i have one in my pan... near of the oil filter, inside the pan!
Old Apr 18, 2010 | 09:08 AM
  #258
delete the DOD.. you will have free HP
Old Apr 23, 2010 | 07:42 AM
  #259
I finally receive my moroso 20140 oil pan... but i have 3 different dip stick, one from my L76, one from a TB SS, and one that i receve whit the oil pan, an other GM dip stick. the 3 dipstick have different lengh... whit one i need to use ? what is the ADD and FULL level on this pan...? someone can anser me ?
thanks..
Old Apr 24, 2010 | 10:55 PM
  #260
BA.'s Avatar
BA.
just drop in the 4 or 5 quarts, whatever you'll be running,....and try them all out.
expecting none of them to be "just right",....pick your favorite dipstick and make a new FULL line based upon the fresh oil you just put in.
