V6 to ls1
Old Nov 21, 2007 | 03:09 AM
Coonass350's Avatar
Default V6 to ls1
hey guys i have seen a camaro for sale here locally for $2,000. it has alot of miles and needs a new paint job. well my question is, how hard would it be for me (an intermediate level with this) to swap the v6 out with an ls1?? please give me some input.
Old Nov 21, 2007 | 05:29 AM
chevycamaro350tpi's Avatar
What year is the camaro?
Old Nov 21, 2007 | 09:13 AM
Coonass350's Avatar
the camaro is a 1997 and there is another that is a 1995.
Old Nov 21, 2007 | 09:31 AM
bczee's Avatar
It is not that hard, you would need to get a 98+ K-member or a aftermarket K-Member.. then everything else from a donner car (find a wrecked donner).
Engine with all accessories, wiring, PCM, BCM, Trans, fuel tank or upgrade the 97/95, etc.. If you have to piece all of the parts.. it will not be very cost wise to do it.
It would be just a complete upgrade with OEM parts. Check out some of the early Gen 4 F-Body that have already been upgraded to Late Gen 4 F-Body drive train.
Old Nov 21, 2007 | 11:05 AM
Coonass350's Avatar
ok thanks for the help. i am going to try it as soon as i save up a little bit of $$
Old Nov 21, 2007 | 12:30 PM
95GreenZ28's Avatar
Put it in the 95 Thats what I did
Old Nov 21, 2007 | 01:08 PM
blackhawk400's Avatar
not to hijack the thread but, hows the clearance under your ss hood 95greenz28? ive been looking around for an older (clean) body for dirt cheap to swap an ls1 into, but the warnings are always that the ls1 doesnt fit under a stock type hood. that instead either a huge cowl is needed or a front end 98+ swap.
Old Nov 21, 2007 | 01:49 PM
Coonass350's Avatar
yeah how is the clearance?? will it fit in there without any problems with the stock hood and stuff?
Old Nov 21, 2007 | 02:38 PM
Wing Zero's Avatar
I would go with the 97 due to the OBD2 system for the 98 on up wiring. The only thing to look out for in the wiring is power feeds and auto to standard transmissions. The engine harness will fit just like the cars with V8s from factory. Most V6 cars do not have ignition power feeds for the V8, so you may need to add some powers. If you get as much of the doner car as possible then you will be ok
Old Nov 21, 2007 | 02:48 PM
Coonass350's Avatar
okay i appreciate it. what is a power feed exactly? sorry i am still kinda new to this. also what is better in yalls opinion, auto or manual??
Old Nov 21, 2007 | 02:55 PM
I Like 6spd Manual For Playing Around In Town, While I Like Auto For Straightline Punches And Races. Ive Had Both, A 98 Auto T/a And An 01 6spd Firehawk. I Like Being Lazy In The Auto, But The 6spd Was A Blast To Play With.
Old Nov 21, 2007 | 03:42 PM
Coonass350's Avatar
well dang, you like both lol i was looking for more of a one or the other opinion lol. what is a little faster? manual or auto??
Old Nov 21, 2007 | 03:46 PM
My 98 Auto Was Way Faster, But I Had Put $3k Into It. I Dont Know What Size Final Gear The 6spd Had, But The Auto Had A 3.42. That Alone Will Completely Change The Way The Car Feels. My Opinion On The Auto Vs. Manual Choice Is Based On Gear Change Speed. An Auto Will Shift Faster Than You Can In A 6spd, But Theres So Much More Control In What Gear You Want At A Certain Time. You Can Manually Throw The Car Into 2nd Or 3rd In A Manual To "go Baby Go" Or You Can Punch The Throttle On The Auto And Hope It Gets To The Right Gear.
Old Nov 21, 2007 | 04:16 PM
camaro-94-z28's Avatar
im about 99% sure u dont need a new hood. ive been doing alot of research for this swap to (lt1 to ls1)
Old Nov 21, 2007 | 05:58 PM
Coonass350's Avatar
camaro-94-z28, thanks for letting me know that i wont need a new hood, but i was thinking about a 6.0 instead of the 5.7 ls1. a friend of mine had a 6.0 in his truck and it was badass.
Old Nov 21, 2007 | 11:41 PM
RE AND CHERYL's Avatar
The stock LS1 filter/intake air box will not fit inder the LT1 hood.
If you don;t currently have a Camaro I would suggest you look around for a 98-99 LS1 car. They are getting quite cheap and after buying a car and everything to conver it you will have spent more than the price of a LS1 Camaro. If you don;t like the look of the LS1 front clip, swap it. Swaping the clip is way cheaper than swaping the motor.
Re'
Old Nov 22, 2007 | 12:02 AM
Coonass350's Avatar
RE AND CHERYL, i was thinking that but i cant seem to find a 98-99 ls1 car for less than 5,000.. thats really all i can afford to spend on the car itself. i found a 99 trans am for 3200 that had 74k miles but i think something must be wrong with it because the exterior looks great and it has a 427 engine. what you think?
Old Nov 22, 2007 | 08:02 AM
Coonass350's Avatar
i really dont want just an ls1. i was wanting to get a 6.0L block and bore it and completely build it and then install it in the car.
Old Nov 22, 2007 | 12:29 PM
Re'
i remember seeing on here somewhere sombody put a ls1 air box on there lt1 and they just removed or modified the plastic piece above the radiator
Old Nov 22, 2007 | 03:27 PM
Coonass350's Avatar
oh okay. so is the wiring very hard on it. for the ecu? i hate messing with wiring, just wondering if it is very hard if i was to swap from the V6 to the 6.0
