Pics of my friend's '82 LS10
Old 11-28-2007, 12:46 PM
Horsepwraddict's Avatar
Originally Posted by SatisTraction
here is a $225 option
that link says $129
Old 11-28-2007, 12:50 PM
fastSS_LS1's Avatar
That's one bad *** truck. I like the color of it too.
Old 11-28-2007, 01:49 PM
94snake's Avatar
IIRC he looked at that one. Due to the mounting position of that one and the frame of the truck, it wouldnt fit though.
Old 11-28-2007, 01:52 PM
LS1TECH Sponsor
Carshopinc.com's Avatar
Yes that is a option, but the location is the same as stock so using stock brackets would be much cheaper not to mention it does not fix the steering box clearance problem.
Old 11-28-2007, 01:59 PM
LS1TECH Sponsor
For racing applications in cars that can fit the alternator in the stock location this would be great.
The fine print says this:
Note: this kit is designed to be used with an electric water pump and no power steering or air conditioning.
Old 12-05-2007, 09:44 AM
LS1TECH Sponsor
Any updates guys?
Old 12-05-2007, 10:32 AM
94snake's Avatar
Nah nothing much. Fuel pump is mounted and I think he ordered all the line and fittings so we can start on that soon. Maybe in couple more months or less and we can fire it up.
Old 12-06-2007, 04:31 PM
BLWN1's Avatar
Originally Posted by Carshopinc.com
I can also sell this kit for a bit cheaper for alternator only relocation, it will work with stock F body accesories and power steering.....
Define? What alt is used....
Old 12-07-2007, 10:49 AM
LS1TECH Sponsor
It uses a Cs style alternator that is smaller than the original unit and not the stock alternator. Did you sell that malibu?
Old 12-07-2007, 11:21 AM
BLWN1's Avatar
Cs?
No still got it, and everything to get it together, need it?
Old 12-07-2007, 04:02 PM
LS1TECH Sponsor
When you comming back to town? You still driving the red car?
  #32
LS1TECH Sponsor
The cs is a style of gm alternator used on light duty trucks and some front wheel drive cars....
Old 12-11-2007, 06:59 PM
  #33
94snake's Avatar
Got a couple new pics. Nothing major, but the fuel system is done and the ignition box & harness is on.
Old 12-11-2007, 07:31 PM
  #34
Spike-Z's Avatar
Those black braided lines looks awesome. Are those Russel?
Old 12-11-2007, 08:03 PM
  #35
94snake's Avatar
Im pretty sure that is Russell line. Its made of nylon and is MUCH easier to work with than the stainless stuff.
Old 12-12-2007, 01:25 PM
  #36
PPI Typhoon's Avatar
If that setup went far enough back to use the Corvette balancer, I'd buy that kit That's exactly the type of setup I need to run the turbo in my Typhoon LSx swap.
Old 12-12-2007, 04:30 PM
  #37
LS1TECH Sponsor
The alternator is already flush with the head in this application I can't move it back any further..... Are you sure you could not make the f-body unit work?
Thanks
Carshopinc
Old 12-13-2007, 07:16 AM
  #38
Thanks
Carshopinc
Well the F-body isn't as close in to the block as the vette's, so it would interfere with the e-fan setup. I could move the radiator forward, but I want to run A/C and a FMIC for my turbo setup, so that would run into that. I probably will just go with an S&P setup or the Newman brackets, but that would put my turbo rather far out from the motor, which would cause me to have to fab a bracket anyway to support the turbo to prevent the header from cracking.
Here's a pic of a fellow SyTy owner with a turbo LSx motor, and you can see his turbo is pretty far out in the fender:
I dunno, I may fab up a bracket on my own. I have access to a laser cutter and he would only charge me the time and materials, which would come out to be like $50 total for the bracket. I just need to figure out if anyone else offers an alternative before I put in the time mapping it out in CAD
It's hard doing this when few others have before.
Old 12-13-2007, 07:26 AM
  #39
94snake's Avatar
^Thats badass. Are you still able to keep the AWD with that swap?
Old 12-13-2007, 10:22 AM
  #40
LS1TECH Sponsor
Can the engine be set back a tad to compensate?
Quick Reply: Pics of my friend's '82 LS10
