Pics of my friend's '82 LS10
Old 12-13-2007, 11:49 AM
  #41
colby72olds's Avatar
Originally Posted by Platinum WS6
i love the little trucks with these motors in them!
Damn right
Old 12-13-2007, 01:59 PM
  #42
PPI Typhoon's Avatar
Originally Posted by 94snake
^Thats badass. Are you still able to keep the AWD with that swap?
yes, I have a sheetmetal oilpan that allows clearance with the front diff.
Old 12-13-2007, 02:01 PM
  #43
Originally Posted by Carshopinc.com
Can the engine be set back a tad to compensate?
Well, not in my application. I am having a custom input shaft done for my transfer case to allow a bolt-up option for a 4L80E, and I've already had my custom tranny mount made, so sliding it back would be more of a pain than a benefit.
The wide turbo isn't that big of a deal, it just means more work.
Old 12-13-2007, 02:12 PM
  #44
LS1TECH Sponsor
Carshopinc.com's Avatar
Who is making the input shaft? It sounds like a very stout combo at this point are you worried at anypoint about the front and rear diff's or T case not being able to hold up to those power levels?
Old 12-13-2007, 02:19 PM
  #45
stealth71's Avatar
Just a heads up. Mounting the regulator on the firewall is against NHRA rules if you care. Needs to be 6" forward for safety purposes in case of flywheel, clutch or other explosion.
Nice looking truck.
Old 12-13-2007, 02:31 PM
  #46
94snake's Avatar
Nice looking truck.
Thanks. He had a bracket that mounts the regulator on the pass side of the carb, but it wouldnt work because of where that ignition box sits. I guess maybe we could have mounted the box on the firewall and done it that way, but it can be redone if need be.
The good thing is, the local tracks around here dont usually tech at all so he should be ok for now
Old 12-13-2007, 02:53 PM
  #47
A fellow SyTy board member George Blake has an outfit machining them out of 9310. He's only having a run of 15 made initially, which I got in on the buy for.
The diff's will probably need to be changed out at some point. I'm not shooting for huge HP right now, but more focusing on getting all the best parts I can into the truck during this build.
Oh and the transfer case has been able to hold down into the 8's, so I'm not worried about that one.
Old 03-10-2008, 12:30 AM
  #48
COPRHED's Avatar
Talking
Well guys i almost have this beast ready to crank! If it goes good i will get the cage and exhaust put on it and i will get some more pics and maybe a video or a sound clip i hope! Thanks again for the compliments.
Old 03-10-2008, 01:55 PM
  #49
LS1TECH Sponsor
Hurry Up We need pictures!
Old 03-11-2008, 12:39 PM
  #50
Is your buddy from B-ham too, there's a s10 that's identical (pretty sure it has the same wheels) in my town.
Old 03-11-2008, 01:44 PM
  #51
jwindbigler's Avatar
That is one sweet *** truck
Old 03-11-2008, 03:44 PM
  #52
94snake's Avatar
We're both actually from Pleasant Grove. It isnt on the road yet but it may be able to be fired up this weekend. If so, we'll try to get some pics and a vid of it.
Old 03-11-2008, 05:05 PM
  #53
Hell yeah. Film that first fireup of the engine...and the first burnout!!
Old 03-11-2008, 05:06 PM
  #54
Oh by the way, do you need anything else from an LS1?? Im parting mine out and want to sell some stuff. I have an intake for $350 shipped if you want it. Its a BBK 85mm manifold, and I will even throw in the MAF too.
Old 03-11-2008, 06:02 PM
  #55
COPRHED's Avatar
Nah don't need anything right now i was actually considering using a blowthru carb and putting a turbo on it. but thanks anyway
Old 03-12-2008, 06:20 PM
  #56
yup no prob
Old 03-12-2008, 08:09 PM
  #57
lt4malibu's Avatar
Originally Posted by SatisTraction
BMR charges $129 for that kit...
http://bmrfabrication.com/misc.HTM
Old 03-12-2008, 11:42 PM
  #58
RE AND CHERYL's Avatar
Ditto...I used to have a friend with a AWD Typhoon with a heads/cam LS1 in it. I was almost afraid to ride in it. It was STUPID FAST.
Re'
Old 03-27-2008, 07:44 AM
  #59
94snake's Avatar
Well it is finally alive. Still has a few small things to go before it is 100% though. It should be back at my house this weekend, so we will try to get some more pics and maybe a vid of it.
Old 03-30-2008, 04:11 PM
  #60
94snake's Avatar
Ok, here are some new pics and a short video of it. Still got to get the 12 bolt and other things done before its track worthy.
Dakota Digital dash:
Idle vid (carb needs some tuning and its idling too high):
The exhaust will be getting installed tomorrow, so it will sound a lot better then
Quick Reply: Pics of my friend's '82 LS10
