Ls1 into a 74 TR6
Old 12-01-2007, 11:39 PM
waterhook1's Avatar
Default Ls1 into a 74 TR6
I will post some pic's soon
Old 12-02-2007, 12:35 AM
Coup D E'Tat's Avatar
As someone who has considered something very similar to this, I would love to see pics!
Jesse
Old 12-02-2007, 05:08 PM
Sabre002's Avatar
no better time then now?
Old 12-05-2007, 09:59 PM
waterhook1's Avatar
Default pic's are here
I have a long way to go but it does fit. The car will weight around 2400 pounds when done. I beleve it will be fun. I might be adding the universal sts turbo system remote mount in the back which will increase a stock engine...to around 475 rwh or more. T56 with give me great gas mileage
cheers!
Old 12-15-2007, 11:06 PM
lsxyj's Avatar
thats gona be neat
Old 12-16-2007, 07:11 AM
rao
rao's Avatar
Looks like fun
Old 12-16-2007, 07:56 AM
Spike-Z's Avatar
Which rear end did you go with?
Old 12-22-2007, 09:54 AM
waterhook1's Avatar
I went with a R200 out of a Q45 Nissan 3.54.1 ratio viscous lsd differential. I will post some pictures later today, and the brackets I used. I will show all the welding done to beaf up Diff area. Went with coil over suspension in rear and converterd over to 240sx disk brakes and caliper has e-brake on it. In the front used Toyota 83 4 piston disk brake caliper... was a direct bolt on. The picture above shows a different setup that has been revised for the disk brake setup.
Old 12-23-2007, 11:00 AM
Spike-Z's Avatar
Cool. Cant wait to see more!
Old 12-24-2007, 10:15 AM
Monza355's Avatar
What headers are those and could you post up more pics of the headers?
thanks
Old 12-24-2007, 12:10 PM
Super Moderator
Reckless's Avatar
I saw a TR6 at the golf course the other day and immediately wondered whether an LSx would fit in there Nice project!
I was also wondering about a Spitfire
Old 12-25-2007, 12:29 PM
Stang Killer's Avatar
that little bugger is gunna get with it!! looks good man!
Old 12-25-2007, 12:49 PM
Sabre002's Avatar
Ya I'm still thinking about taking out the Rover V8 and putting a LS1 in my MGB.
Old 12-30-2007, 10:41 AM
waterhook1's Avatar
thanks
Hooker Headers from Car Shop Inc. Part # 2312 uncoated block hugger.
Attached Thumbnails Ls1  into a 74 TR6-headers1.jpg   Ls1  into a 74 TR6-header2.jpg   Ls1  into a 74 TR6-header3.jpg
Old 12-30-2007, 10:43 AM
waterhook1's Avatar
Have you ever checked out Britishv8.org?
Old 12-30-2007, 10:50 AM
waterhook1's Avatar
more pic's
Attached Thumbnails Ls1  into a 74 TR6-diff.jpg   Ls1  into a 74 TR6-diff-reinforcements.jpg   Ls1  into a 74 TR6-coil-over-shock-reinforcement-diff-mounts.jpg   Ls1  into a 74 TR6-bolt-motor-mount-cross-member.jpg   Ls1  into a 74 TR6-cv_axle_400x250.jpg
Old 09-30-2018, 09:20 AM
Mac Queen's Avatar
Default Ls3 into a 67 Spitfire
Hi I'm new to the form .I am putting a ls3 into a 67Triumph Spitfire i was wondering if you could put more pictures up so i could learn what it takes to do this kind of job.
Old 09-30-2018, 10:00 AM
Michael Yount's Avatar
Take a HARD look at frame reinforcement on the TR6, especially at the rear end. They're notorious for cracking/breaking and 3-4x the torque will exacerbate that issue. Got a buddy who had a 3.4L V6 powered one, and he pulled that and put a new crate Ecotec 2.4L in it.
Old 09-30-2018, 10:31 AM
jarheadl34's Avatar
Wow! Looks like it could be a fun ride going straight, crossed up at speed it could get very interesting.
Jarhead
Old 09-30-2018, 10:53 AM
Received 3,146 Likes on 2,453 Posts
Basically, lift Spitfire body from frame, build new frame and totally reinforce front and rear suspension, and add larger rear axle.. Oh and WAY bigger brakes all around. Still worth it?
Quick Reply: Ls1 into a 74 TR6
