LSX in 87' Fox
Old Dec 19, 2007 | 10:23 AM
djquik88's Avatar
If you notice in my pics mine had manual brakes also, but that didn't last long .lol
As far as the fuel pump goes, The Speartech harness has a fuel pump relay already wired up. I just ran the wire from the relay into the trunk and connected it to the factory wiring just before it goes through the trunk pan to the pump.
Mike
Old Dec 19, 2007 | 12:31 PM
tirefryin_s10's Avatar
Originally Posted by 97'-lt1
I want to ba able to drive it to and from work on occassion, which includes decent traffic, this is why I have decided to keep the power brakes.
LOL i drive my car all over the placei n heavy traffic etc and it stops just fine ...
Old Dec 20, 2007 | 09:33 AM
97'-lt1's Avatar
What are you guys using as far as throttle cables?
Old Dec 20, 2007 | 10:00 AM
djquik88's Avatar
I have seen where some people said they used the factory 4 banger cable, but mine was to short. I am using a factory 5.0 cable and it fits perfect.
Old Dec 20, 2007 | 10:53 AM
97'-lt1's Avatar
Cool..I should be good to go there then.
Old Dec 27, 2007 | 04:17 PM
97'-lt1's Avatar
Ok next on my list is the fuel system..did some researching but can't really find details on the fuel setups some of you foxbody boys are using. djquik88 has given me some info on his, but looking for more information. The more you know the better right?
Old Dec 27, 2007 | 09:54 PM
djquik88's Avatar
Have you looked at the tread on here by powershiftkung, on the PHR project called the Orphan? There is a ton of info to be found in his build.
https://ls1tech.com/forums/showthrea...161&highlight=
Old Dec 28, 2007 | 11:15 AM
97'-lt1's Avatar
Thanks for the link..Awsome thread..Answered alot of of my questions. That link never came up and any of my searches though, weird..
Old Dec 28, 2007 | 04:05 PM
djquik88's Avatar
Yeah, that thread is what made me sell my BBF stuff...lol
Old Jan 15, 2008 | 06:00 PM
97'-lt1's Avatar
Need some more fuel help. I'm going to be running a truck intake and fuel rails..and at this point an time am planning to run a return style fuel set-up. My question is will I just use the factory regulator on my stock rails or run an aftermarket regulator? Such as a Aeromotive..etc..?
Old Jan 15, 2008 | 06:14 PM
lt4malibu's Avatar
if the truck rails have a return you can use the stock Rail-mounted regulator, you'll just have to run the lines
Old Jan 17, 2008 | 10:45 AM
  #32
rss0694's Avatar
Whay dont you buy my procharger set up for that fox.
Old Jan 17, 2008 | 11:06 AM
  #33
97'-lt1's Avatar
Lol I wish..If I had the money I would..I'm doing my swap in stages I guess you could call it. Just slowly gathering parts..Christmas is a bitch.. Haha
Old Jan 17, 2008 | 11:15 AM
  #34
97'-lt1's Avatar
Well decided to sell the 4L80 and go with a Th350-400, cheaper to build and cheaper converter, plus haven't been able to find a cheap controller for the 80..so Th400 and a brake is in the works..
Old Feb 6, 2008 | 01:11 PM
  #35
97'-lt1's Avatar
Ordered my K-member and spring perches today. K-member is on back order every where.. So that sucks, they said it could be beginning of March before I see the K-member..Should be picking up my heads next week hopefully and ordering the cam shortly after. Pick up a new car pan, tray, gasket, bolts, and sender last week, along with a LS6 oil pump. So I should have the motor back together hopefully in 2-3 weeks depending on the how long the cam takes..
Old Feb 6, 2008 | 09:22 PM
  #36
lt4malibu's Avatar
i ordered my Kmember around the same time last year and i got the same answer, i guess alot of people builing cars over the winter for the spring???
Old Feb 7, 2008 | 11:37 AM
  #37
97'-lt1's Avatar
I guess so..Make me wonder how long the headers are going to take, makes me want to order them now just in case..But I guess just give me more time to detail..Haha..How's your car doing?
Old Feb 7, 2008 | 11:50 AM
  #38
lt4malibu's Avatar
waiting for more parts
Old Feb 7, 2008 | 12:34 PM
  #39
stangH8TR's Avatar
I've just recently started looking at LS1 Tech and saw some of the links that have been posted in this thread for my swap. Is there isn't a specific forum for the LS1-Fox Body swap is there? A lot of what I've has helped me plan on what to do. I found an 87 notch roller that had an existing AJE K-member and I'm about to send it back to AJE and have them weld the LS1 mounts on. I want to go forced induction maybe either with a 122 maggie or twin turbos, any sugestions?
Steven
Old Feb 7, 2008 | 03:37 PM
  #40
97'-lt1's Avatar
Lol so the same boat I'm in..well sorta. At least yours is together..
