LSX in 87' Fox
Old Oct 29, 2009 | 09:48 PM
  #221
bad6as's Avatar
race weight?
Old Oct 30, 2009 | 07:57 AM
  #222
97'-lt1's Avatar
Well it was 2980 with me in it, but some things have changed since then. Will find out new race weight today..
Old Oct 30, 2009 | 04:06 PM
  #223
bad6as's Avatar
how much do you weigh?
Old Oct 30, 2009 | 09:18 PM
  #224
97'-lt1's Avatar
Well new race weight 2843 with me in it..I weigh 185-95
Old Oct 31, 2009 | 01:26 AM
  #225
JRracing's Avatar
we are very close Kevin, I'm at 2830 with me and gear.
The pics are awesome. it's coming along nicely. I love the wheels. I wish I could splurdge on a set evo's or bogart's. But I have to buy some susp stuff and get the n2o put on over the winter.
Hurry up and get it to the track. I want to see what she does..
Old Oct 31, 2009 | 01:38 AM
  #226
JRracing's Avatar
what hood is that? 6"? Looks like the one I just got from champion hoods and deck lids out of cinci.
Did you do the rear seat deleat yet? If not look up scottrodsfabrication.com. His work is awesome. look at my pics to see mine. It's a little pricey at $350 but well worth it. He can do them in any color also. Just an fyi.
Were did you get the zuas rail for the hood? I would like to find a nice set for my hood.
Old Oct 31, 2009 | 12:24 PM
  #227
bad6as's Avatar
you have any idea on what mine might come out to be?
87 notch, no heater box, manuel locks and windows, 8 pt mild steel cage, 8.8 rear, 6.0l iron block, th350, and turbo kit?
Old Nov 1, 2009 | 04:45 PM
  #228
97'-lt1's Avatar
Hope to get it back to the track this weekend for some testing. The hood is a 6" harwood. Yeah I had my buddy that put the hood and built the zeus rails for me put in a seat delete. He made my rails from scratch but RaceCraft makes some, I think they're like $75.
Really hard to say man. The turbo stuff will add some weight for sure. Other than your turbo stuff, your car is pretty much the same as mine..
Old Nov 2, 2009 | 01:08 PM
  #229
97'-lt1's Avatar
Well I decided to make some fuel system changes. Before I only was using #6 line, one pump, and one regulator, for both the motor and nitrous. I am adding #8 line for the motor and using the #6 to supply to fuel for the nitrous. So now the motor and nitrous will have their own pumps and regulators so I can better control and tune the car. Built the new lines yesterday, picking up the nitrous fuel pump tonight. All thats left is to mount the pump and regulator and hook up the lines, then flow everything. Plan to hit the track for some testing this weekend..
Old Nov 2, 2009 | 03:56 PM
  #230
bad6as's Avatar
im only 150lbs, but i was planing on 3200lbs but hell the lighter the better! still undecided if im gonna have lme or va speed build my longblock, and where to get my th350 from. prob gonna go with va speed and performabuilt
Old Nov 2, 2009 | 08:57 PM
  #231
JRracing's Avatar
Coan Transmission here in In, has always been a big player in drag apps. They can build a th350 to what ever power level you need. Or get a th400 for a heavier car.
Or a Rosler th350. Top notch stuff.
Old Nov 2, 2009 | 09:02 PM
  #232
JRracing's Avatar
Kevin, that is how I am doing mine. I got a hp150 pump this summer and took the hp125 off. So i'll hook it to the other port on the bottom of the tank and run it up to a reg for the n2o. Should make for a sweet setup. And to fine tune the fuel for the plate with out messing with the motor's fuel flow.
  #233
-JP-'s Avatar
my car is almost back from the chassies shop i cant wait to start my project great job again with your car
Old Nov 3, 2009 | 09:46 AM
  #234
97'-lt1's Avatar
Thanks JP
Yeah thats exactly why I'm making the fuel changes. Makes for more precise tuning.
Old Nov 5, 2009 | 11:17 AM
  #235
383transam's Avatar
Im putting a th400 in my ls1 notch, do I need the short tail shaft version? You've got a nice *** car!
Old Nov 9, 2009 | 10:11 PM
  #236
bad6as's Avatar
guys my 87 im swaping has a aje k member and a flaming river manuel rack. well i bought a steering shaft off ebay, and well its to short. whats the deal? here is my ebay item. sorry for the hj but all the swap guys are all ready posted in the thread so i figured i get a quick answer.
http://cgi.ebay.com/ebaymotors/Musta...item5184f10ecb
Old Nov 11, 2009 | 08:26 AM
  #237
JRracing's Avatar
I got the joint from speedway motors and made my own for about $65. I got the "D" shape shaft from them also.
Old Nov 11, 2009 | 10:21 AM
  #238
bad6as's Avatar
all fixed. the shaft that comes off the collom moves some. so mine was pushed in making it look like the shaft was to short. pulled it out some and works great.
Old Nov 30, 2009 | 02:49 PM
  #239
97'-lt1's Avatar
Well just an update, Since getting the car back together with the new motor, been back to the track once. I am pretty happy with the car for the first time out with the new setup. All passes were made off the footbrake because my transbrake button broke. With the car having nitrous timing and #8 ngk plugs the car went 6.5 on the motor which is a tenth better than the old motor. I figure with motor timing and plugs I could probably get a 6.3-40 out of it pretty easy. Went a 6.02@117 in the 1/8 on a 150hp. Heres a couple pics a video where I got out cause she was headed to the tree..No video for the 6.02 pass, the camera decided to die during my burnout...
View My Video
Car was going left a little, so I adjusted the anti-roll bar a little and then went to start the car and heard some strange noise coming from transmission area so just loaded it up and took it home. Once I got it home figured out the converter bolts had came loose so went ahead and pulled all of them locktited them again and retorqured.
Once I get it back out with some new tires and do some more tweaking of the front suspensions and anti-roll bar, the car should easily go a 5.80-90 on the 150. Then I'll pill it up from there..Goal is to go some mid 5.50's or faster next season.
Old Nov 30, 2009 | 10:04 PM
  #240
ryclef331's Avatar
God DAMN son that thing hits HARD! I love it. I hope my 94 runs that good....awesome.
