LSX in 87' Fox
Old Dec 2, 2009 | 10:45 AM
  #241
97'-lt1's Avatar
Thanks
Old Dec 2, 2009 | 05:59 PM
  #242
Dickie-311's Avatar
whats the new motor/.... i didnt read all of this..thanks
Old Dec 2, 2009 | 07:38 PM
  #243
06colorado's Avatar
Looks sweet!!!!
Old Dec 2, 2009 | 07:46 PM
  #244
97'-lt1's Avatar
408 12.5 compression
AFR 225s
Comp Pro magnum rockers
Crane dual valve springs
Chromoly Pushrods
Hydraulic roller camshaft 248 254, 615 625 110 @ .050
Crane double roller timing set
Diamond Nitrous pistons
eagle 4340 rods
eagle 4340 crank
1/2" ARP head studs
Old Dec 3, 2009 | 05:10 AM
  #245
Dickie-311's Avatar
AFR 225s
Chromoly Pushrods
eagle 4340 rods
eagle 4340 crank
1/2" ARP head studs
nice ..should be close to 9's on motor now
Old Dec 3, 2009 | 11:44 AM
  #246
mred's Avatar
Final Combo will be a 6.0 LQ4 short block, Texas speed 228R cam, 853 casting heads ported very well flowing over 300cfm and milled .048" putting the compression somewhere in the 11.0-12.00 range, Vic Jr. intake with a ProForm 850 on top.
how is this even possible? doing the math,i was told the heads were milled down .120?
just asking?
so have you been running this combo all along,minus the afr heads?VVVV
AFR 225s
Chromoly Pushrods
eagle 4340 rods
eagle 4340 crank
1/2" ARP head studs
Old Dec 3, 2009 | 06:28 PM
  #247
97'-lt1's Avatar
No the motor I have now is a completely different motor (2nd thing you quoted) from the first one. The first one was just a stock 364ci short block LQ4 with a TSP 228R and some 853 casting heads that were ported and milled only .048.
Old Dec 3, 2009 | 10:16 PM
  #248
mred's Avatar
not arguing with you,but i am asking how did you achieve 11-12 compression range,with the first build.
thanks
Ed
Old Dec 4, 2009 | 02:10 PM
  #249
97'-lt1's Avatar
I never really checked the CR of the first motor. Was basing it off what I was told by the previous owner of the heads and a few others when I bought the 853 heads. When using a factory MLS gasket and the stock LQ4 pistons..
Old Dec 4, 2009 | 03:40 PM
  #250
mred's Avatar
never less the motor did run like a rapped ape.
i will say for a LQ4 with 10.1 and a 228r cam that sucka did move out pretty damn good
Old Dec 4, 2009 | 08:04 PM
  #251
97'-lt1's Avatar
Thanks..it definitely got with it..
Old Dec 4, 2009 | 08:10 PM
  #252
orangejuiced86's Avatar
This is the main build that got me to build an LS mustang! I was defiantly impressed with how the lq4 ran.
Old Dec 4, 2009 | 08:25 PM
  #253
97'-lt1's Avatar
Thanks man..
Old Dec 7, 2009 | 09:23 PM
  #254
Dickie-311's Avatar
can i see more detailed pic's of your alternator mounting ..thanks
Old Dec 8, 2009 | 08:36 AM
  #255
97'-lt1's Avatar
I'll have to see about taking some. Its just the bmr low mount bracket though..just installed a little different...
Old Dec 8, 2009 | 03:05 PM
  #256
turbo_ase's Avatar
Quick question there if you don't mind...How much horse power a LQ4 with Z06 cam LS2 intake and a 4L60E tranny should do.I'm keeping it stock is going to be my DD.
Thanxxxxx
Old Dec 8, 2009 | 03:23 PM
  #257
97'-lt1's Avatar
Honestly man I'm not really sure, it will depend on your tune really..
Old Dec 8, 2009 | 04:29 PM
  #258
mred's Avatar
Thanxxxxx
LOL
500 Million.
no really 380
Old Dec 9, 2009 | 09:27 PM
  #259
JRracing's Avatar
Right on Kevin. That is rollin! We would be a good race. My car goes mid 6.40's to low 6.50's spinning.
Your car is hooking really hard to the left. Were the tires check right before the run? Were they dead even? Or is something not squared in the rear end? It looked like a fun ride lol.
What kind of 60'? Was it a slick or DR?
It will be sick when it all comes together. Congrats man!
Old Dec 10, 2009 | 09:36 AM
  #260
97'-lt1's Avatar
Thanks, yeah I'm pretty confident that it would go 6.3x if I put some motor plugs in it. I might play around next season with it to see what it will do..
Yeah I checked tires before every run..The anti-roll bar was loose on the drivers side for some reason..whoops..lol
The 60' for the pass on the video was a 1.27, on some wore smooth the hell out MT 28x10.5 slicks. Got two new sets for next season at home.
Yeah I'm really excited for next season to get here so I can get out and do some more testing, to get it lined out for the classes I'm running in next year..
