LSX in 87' Fox
Old Dec 5, 2008 | 07:48 PM
  #141
wheelies247's Avatar
3.90 might work good run out right at the end of the 1/4 mile
Old Dec 6, 2008 | 12:38 AM
  #142
JRracing's Avatar
Right now the car has a Hoosier 27x10.5 4.56 and th400 with about a 4500 verter. I plan on buying at least a 28x11.5 or a 275/60 DR. And maybe a different gear lol. But I have a bigger cam and I plan to spin the motor around 7K to 7500 rpms.
Old Dec 6, 2008 | 08:56 PM
  #143
97'-lt1's Avatar
I forgot you will be able to spin it higher safely, but there's no reason for me to spin it that high, with it being a mild set up, the car doesn't really keep making power past 6500..But I'd still bet you will probably run out of gear...
Old Dec 8, 2008 | 11:44 PM
  #144
JRracing's Avatar
I think your right. I will run it first and then determine what size gear. I think a 4.10 should be just about perfect.
I would like to find a gear that will work awesome with a 28" tire on the spray and pretty good with a 26" tire for motor only.
  #145
JRracing's Avatar
Did you find those header pics?
Old Dec 27, 2008 | 12:41 PM
  #146
01Z28Camaro's Avatar
Really liking the outcome of this car
Old Dec 27, 2008 | 01:42 PM
  #147
Darracq's Avatar
My old nova had 4.10s and crosed the line at about 6900 at 130mph. With a 28x9 mt measures 27tall.
Old Dec 27, 2008 | 05:48 PM
  #148
HUNTER02SS's Avatar
What oil pan do you use for the swap?
Old Dec 27, 2008 | 11:01 PM
  #149
lt4malibu's Avatar
f-body pan fits best and has the most ground clearance, a truck pan will work but hangs low.
Old Dec 28, 2008 | 06:49 PM
  #150
97'-lt1's Avatar
Thanks the car is a blast...Very happy with the car..
Like lt4malibu said, most use a fbody pan, but the truck pan clears just fine..tirefryin_s10 is using a truck pan...
Old Dec 30, 2008 | 11:26 AM
  #151
Espresso's Avatar
Damn where do you guys find these $300 dollar deals!
Old Dec 30, 2008 | 01:21 PM
  #152
97'-lt1's Avatar
Just happen to be in the right place at the right time I guess..Before I found mine, pullouts from camaro/transam were going for $2k and up...
Old Dec 30, 2008 | 02:20 PM
  #153
Qwiknotch's Avatar
Man the car car is working well...Nice job!
Do you have any other close up pics of the headers and K member? I just ordered a set of kooks 1 7/8" for my car but I'm uncertain if they will fit. I have a PA K member with ls1 plates and had a guy re weld it up. So there is no guarantee if they will fit but I will make them work.
10.50's on a mild set up like that is awesome. I can't wait to see what happens with the sauce...
What size slick did you buy? I have a 27" right now with a 4.56 and th400. I'm really worried that will not make it to the 1320'. But I'm waiting for a guy who is going to wire the car and possibly mini tub it. Then I could go with a 29" or 30".
If you are not going to spray it, you will be fine. I shifted mine at 6700 with 456 gears and a 26/10 slick and went out the back door at 6800
My new engine, I am going to shift at 7500 with 488 gears with a 27/10.5 Hoosier QTP. I might even put a 513 in it. We shall see. It is going to be all motor with a Jerico, so I can put a different 1st gear in it, if it doesn't make it.
Old Jan 18, 2009 | 07:09 PM
  #154
97'-lt1's Avatar
Well it was nice today so I decided to take the car for a drive today. Drove out to my brother's and put it on the lift and took some pics in his shop...
Also took a few shots of it on the lift and the exhaust and such..Here's the link to them...
http://community.webshots.com/album/...bCnIe?start=48
Old Jan 18, 2009 | 11:55 PM
  #155
JRracing's Avatar
Looks pretty good. I like the wheels on it. The bottom of the car could used a clean up and some paint lol. Must be nice to be out driveing your hot rod around. It is pretty cold here and a bit of snow still around. Main roads are clear but side streets are slick.
Your brother hooked his shop up. He finished it out nicely. I like the tile floor look.
Old Jan 19, 2009 | 08:07 AM
  #156
97'-lt1's Avatar
Thanks..Yeah it could use some clean up, but no one really ever sees it. That's the first time its been on the lift. I did the whole swap in my garage on the floor.
I love the wheels, they're dead sexy. Plus now I have no reason to convert to 5 lug.
Yeah its been pretty mild around here this year. We've had some cold weather but not really any ice/snow.
I agree his shop turned out awsome, I don't think he's used it to it potential yet but hopefully he will soon.
Old Jan 19, 2009 | 10:00 AM
  #157
Eric Fischer's Avatar
I love the wheels. What kind are they?
Old Jan 19, 2009 | 10:39 AM
  #158
97'-lt1's Avatar
Thanks..Bogart D-10's
Old Jan 19, 2009 | 12:25 PM
  #159
lt4malibu's Avatar
the bogarts look killer! i was looking at the D10's myself...
Old Jan 19, 2009 | 01:13 PM
  #160
97'-lt1's Avatar
I love them...I couldn't pass them up..I got a smoking deal on them...
