A body oil pan clearance
Old Dec 14, 2007 | 06:29 PM
matty b's Avatar
Default A body oil pan clearance
I got a 64 chevelle and Im getting ready to drop in a 5.3 with S&P mounts and was wondering if the truck pan will clear the crossmember on it. I heard that the F body pan should clear but I dunno about the truck one.
Old Dec 14, 2007 | 07:10 PM
G-Body's Avatar
sawzall wielding director
My guess is that it would clear, but the pan will hang down below the crossmember a bunch. I`m betting at least 2" below the crossmember.
Old Dec 14, 2007 | 09:14 PM
matty b's Avatar
ok then better question what would be the prefered pan to use that I dont need to cut and wont be the lowest part of the car?
Old Dec 14, 2007 | 10:54 PM
matty b's Avatar
nevermind came across a moroso pan that im gonna go with
Old Dec 15, 2007 | 09:14 AM
ryanvv355's Avatar
Autokraft is a reasonable solution also. A little more money but you get to keep the oil filter in stock location. The moroso pan is cheap, but then you get the pickup its adds up to $300, then the cost of a good remote filter. The auto kraft is $425 but packaged well.
Old Dec 15, 2007 | 10:14 AM
TT402LS1's Avatar
When I was fitting my motor in the chassis, I didnt have my Canton pan yet, and the stock 6.0 pan just touched the crossmember. The sump does hang low, but if you were not going to lower it, it my be okay. You would need to put a 1/4" spacer under the motor mounts on the frame to clear the engine crossmember. I have seen a 70 Chevelle with the truck pan, so I know it works.
Ron
Old Dec 15, 2007 | 01:54 PM
matty b's Avatar
no my car is gonna be a low clearance ride pro touring style. Having a remote mount is no prob, I actually have a few from my aircooled vw drag racing days so that and an oil cooler are already in my parts stash. so the moroso it is for me. 125 cheaper than the autocraft (which is a nice lookin pan) and gives me extra oil without ground clearence issues.
Old Dec 17, 2007 | 10:06 AM
Carshopinc.com's Avatar
LS1TECH Sponsor
We used the champ pan for our conversion and still had to modify the crossmember.....
Old Dec 17, 2007 | 11:41 AM
ryanvv355's Avatar
Is champ the pan supplier for Autokraft and Carshop?
Old Dec 17, 2007 | 11:43 AM
LS1TECH Sponsor
I sell and use champ pans...... Not sure about the autokraft unit...
Old Dec 17, 2007 | 01:25 PM
forcd ind's Avatar
not sure how much diff the 64-5 frames are from the 68-72, i know they use diff frame mounts, but on my 69 i used a caddy cts pan, $150, hooker headers and hooker motor mount conversion-hookers push the engine up a tiny bit and back-i know the p/s head ends up 1 1/2" from the firewall-the hookers fit perfect, plenty of ground clearance-i use the corvette acces drive so i can run the rev procharger
Old Dec 17, 2007 | 01:45 PM
LS1TECH Sponsor
The hooker style mounts would not allow us the run a low mounted ac compressor and we had to modify the Hooker headers to fit the chassis.
