My current state of LS1/Nova conversion
Old Jan 14, 2008 | 11:20 PM
ssduane's Avatar
Default My current state of LS1/Nova conversion
Mods listed in sig, got the LS1/4L60e in the chassi as of today.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Jan 15, 2008 | 03:52 PM
66 NOVA's Avatar
DUANE
It is looking real good! Keep up the good work
Joe
Old Jan 16, 2008 | 12:54 AM
babydeuce's Avatar
**** Duane, your doing it the easy way.....try a stock front end like mine I still think you should have kept the 63!
BTW, Nice to see you made it over here from steves.........
http://good-times.webshots.com/album/557624863pacNjI
Jack
Old Jan 16, 2008 | 05:09 AM
67pete's Avatar
Welcome!
Nothing like making a light car lighter.....
Old Jan 16, 2008 | 07:28 AM
AINT SKEERED's Avatar
How are you all making the oil pan work with the chevy II steering? Also any one know where to get the upswept fenderwell exit headers for these cars?
Old Jan 16, 2008 | 09:37 AM
ssduane's Avatar
Jack
Nice to hear from you again Jack. The 63 was really starting to go away from what I wanted, plus I found this 66 (always wanted a post car) cheap. I finally realized the 502 route was going to cost me way to much money, so I decided to do the LS1 thing.
See you finally gave up on that 283, yours is looking good, nice work on those headers.
Old Jan 16, 2008 | 09:38 AM
ssduane's Avatar
The GTO pans will clear the stock steering as they are a front sump pan.
Old Jan 16, 2008 | 12:30 PM
babydeuce's Avatar
LMAO....the 283 was a lot of fun, and it ran really well for what it was. I sold it a guy off steves board for a fraction of what I had in it, but I too really liked the idea of the LSX style setup. Your 63 was sweet, but I have to say I really do like this 66 your building. Good luck, and keep the pics coming!
Jack
Old Jan 16, 2008 | 01:22 PM
Juicy J's Avatar
Very cool project my friend.
Old Jan 16, 2008 | 01:32 PM
Buckndol's Avatar
The 66 is a very neat body style. You have very little room for rear tires. Are you going to minitub or just let the tires spin a little bit?
Old Jan 16, 2008 | 02:05 PM
BBPanel's Avatar
Veteran: Marine Corps
My stock steering did not clear the GTO pan - I did not determine how much it was off by - but the general comment that it works is not true - every vehicle has different tolerances and my just didn't work out.
Old Jan 16, 2008 | 03:05 PM
ssduane's Avatar
Its already minitubbed and has a 275/50-15 underneath it with about 2 more inches of clearance left.
Very true on the differences, especially on these thrid gens.
Attached Thumbnails My current state of LS1/Nova conversion-dscf3793.jpg
Old Jan 17, 2008 | 12:55 AM
babydeuce's Avatar
It is a good possibility it was the mounts that you chose to use. Some mounts move the engine back, which will cause the steering linkage to hit the pan. I used Transdapt mounts, and modified them to move the engine 1" forward. I have NO issues with steering.
Jack
Old Jan 17, 2008 | 05:14 AM
79nova's Avatar
nice ride duane, i did like your 63,maybe one day i will get my 79 done,hehehe[http://i176.photobucket.com/albums/w...8/100_0132.jpg i need a differt oil pan http://i176.photobucket.com/albums/w...8/100_0156.jpg http://i176.photobucket.com/albums/w...8/100_0109.jpg
Old Jan 18, 2008 | 03:00 PM
Chori's Avatar
what motor mounts are you using?
Old Feb 18, 2008 | 09:01 AM
63chevyll's Avatar
Default LSX in a 63 chevyll info
Jack
I'm thinking of putting a LSX eng in my car. You said you had to move the engine forward 1", was this done to clear the steering linkage? Your pics are very helpful. I'm assuming the block hugger headers won't work?
Old Feb 18, 2008 | 10:50 AM
BBPanel's Avatar
Mods listed in sig, got the LS1/4L60e in the chassis as of today.
Duane, do you know yet if the fbody mounted alternator will clear your steering? What about the a/c on the other side?
Old Feb 18, 2008 | 12:50 PM
babydeuce's Avatar
I actually did it for several reasons. 1. I gained more room in the trans tunnel. 2. I needed more room for the coil brackets from the factory brake booster, and the heater blower motor. 3. I did not like where the heater lines were placed off the water pump.
I highly doubt that you will get block hugger headers in there. I made my own, just finished up the passenger side last night. Still have to weld the collectors and the flanges.
Jack
Old Feb 19, 2008 | 12:54 PM
Novas Forever's Avatar
The factory F-body alternator mounting location will clear with an aftermarket front clip. Forget about the stock A/C compressor though. I mounted the A/C compressor on the passenger side high with some great brackets I found.
Old Feb 24, 2008 | 09:44 PM
1967jaba's Avatar
Default New comer!
Just wanted to say Hi to everyone. I'm building a 67 chevy II. I'm installing a ls2 with a 6-speed. I am also using the stock front clip. Baby deuce has inspired me to build my own headers. I started on them what fun. If you have any more pics would like to check them out. Thanks Jamie.
