Duramax in an F-Body
Old 01-24-2008, 11:05 AM
99mongooSS's Avatar
Im gonna say that this is assonine, now im leaving.
Old 01-24-2008, 03:20 PM
digitalsolo's Avatar
I keep hearing all this about the weight... last I checked an iron BBC wasn't light, and I've seen several of those.
It would likely require strut tower, cowl, and hood work to fit. Doable, but likely wouldn't be pretty.
A 3rd Gen would probably be a lot easier task, with their tank sized engine bays and no cowl-over-motor design.
Old 01-24-2008, 03:48 PM
philntx's Avatar
All anyone needs to do is measure the width of this engine at the exhaust manifolds/heads. This will dissuade the non-fabricator from attempting this swap in an F-Body.
Here is a pic of the Allison trans next to a 700R4 (4L60) type trans....It's very big. Extension trans tunnel modifications. It also weighs 330 lbs...dry.
The financially shy....should not apply...
This motor is huge!
You need to remember that this is a 4 valve per cylinder head also.
Note the oil filter location.
Old 01-24-2008, 11:07 PM
N2DP2QT's Avatar
if only i had just a motor and transmission laying around i think i could do it. can you not turn it into a dry sump? that would make it able to be lower and no oil filter issue - also clear the rack???? i hink it can fit under a stock hood. just take a lil cash for the oiling system
Old 01-25-2008, 12:06 AM
green28's Avatar
I'm no expert, but a 5.3 truck motor with stock intake and accesories won't even fit under a stock f-body hood, and that thing is a monster compared to it.
Old 01-25-2008, 12:09 AM
wg871's Avatar
It would be awesome, think of the torque. But it would be very difficult. If it came through it would be fun
Old 01-25-2008, 09:36 AM
philntx's Avatar
Absolutely no way this would fit under a stock hood or under the cowl.
Dressed engine/wet trans combo weighs in at approximately 1,375 lbs.
Old 01-31-2008, 02:37 PM
project impala's Avatar
I've scaled a Dmax/Allison combo - 1400 lbs. Search for the Pimp My Ride episode where they put a D/A into a '65 Impala if you want an idea of how tall the motor really is.
Old 01-31-2008, 02:43 PM
Jon5212's Avatar
Wait until the 1/2 ton version duramax comes out... believe the packaging will be quite a bit smaller.
Old 01-31-2008, 04:26 PM
LS1TECH Sponsor
Schwanke Engines's Avatar
Schwanke Engines The Duramax probably won't fit. But this one will!!!!!!!
http://www.sae.org/automag/technewsl...108Tech/01.htm
Old 01-31-2008, 04:30 PM
LS698ta's Avatar
wow!!!
Old 01-31-2008, 05:15 PM
  #32
Lafngas98Z's Avatar
Got a friend of mine building a Mustang with a Duramax for drag week. It should be pretty nasty!!!
http://www.competitiondiesel.com/for...ad.php?t=20276
Old 01-31-2008, 06:47 PM
  #33
schwoch1's Avatar
Originally Posted by Schitzo
WOW! I never knew you could shoehorn a Cummins diesel into a Vette, even under the stock hood
Someone did a good job of overlaying the sound clip onto the video !!!
Mike
Old 01-31-2008, 06:55 PM
  #34
Shawn MacAnanny's Avatar
Haha Yeah my duramax definately hauls ***. Has an HPP stage 3, ppe boost valve, open intake, and straight pipe exhaust. been hauling 12k+ just about everyday for the past 35k miles with tune. Engine was diagnosed with a blown headgasket 20k miles ago engine still runs PERFECT added compression just forces a quart of coolant out every tank or so. To me, thats almost nothing. 15mpg towing, 17-18 unloaded but this is in a crew cab 4x4, with 9" Knapheide utility body. I'm going to dyno it and run it at the track when i take my 68 up.
FYI 01 Duramaxes are known for blowing the stock head gaskets, the cost? $4500 thats if the heads dont need to be milled.... and they cant be or so a GM dealer will tell you and they are another $1500 Not cheap at all. Plus all LB7 (first gen) Duramaxes had inferior injectors. GM issued a 200k mile warranty on them and most have been replaced.
I Highly doubt this would fit in an Fbody withough modifying the windsheild or raising the body. These engines are massive.
Old 01-31-2008, 07:04 PM
  #35
LS1TECH Sponsor
ALLBOTTLE's Avatar
not to mention that the dry weight of the motor is ~1100 lbs. that alot of weight to hang over the nose.
Old 01-31-2008, 07:20 PM
  #36
I dont think the weight would be as much of and issue as the dimensions. I just took a pontiac 400 out of my 68 and they are almost 800lbs. I'd imagine a BBC would be around 750 or so and a supercharger and all to it would it put it over 800. If you used the duramax radiator that would create and issue as well. The Duramax cooling system holds something like 12 gallons of coolant. Also the Allison transmission cooler is massive and has 1/2 steel lines running to it.
Old 02-01-2008, 08:06 AM
  #37
zman1969's Avatar
Originally Posted by Ban1dit
I know it sounds redneck, but honestly I don't give a SH#* but I have a few questions.
Sounds REDNECK? buddy that IS REDNECK! this sounds like a really cool project and the rest of us will stand back and watch you do it! either will end up driving around impressing some and the others scratching their head wondering WHY? there is a guy on pro-touring.com building a project car with a new Ecotec turbo with 5 or 6speed in a Chevette! you should check out all the posts -133 and the hits?12,500+ thru the roof! check it out http://www.pro-touring.com/forum/showthread.php?t=35479
WHY? .............
Old 02-01-2008, 08:20 AM
  #38
troopercar's Avatar
I don't think the camaro is big enough for the duramax package even if you went full tube chassis, by the time you got the engine and cooling system the front end would no longer be recognizable.
Old 02-01-2008, 08:23 AM
  #39
Jon5212's Avatar
The link doesn't work. Also I keep saying to wait for the 1/2 ton version of the Duramax cause it will be physically smaller/ weigh less. And it will still have over 300 HP and over 500 FTlb of torque at least according to the magazines.
Old 02-01-2008, 08:32 AM
  #40
troopercar's Avatar
I really want to tell you to just put an 8-71 blown and stroked big block chevy in it for the big torque you want.
But you asked us not to do that so I won't.
The diesel idea is cool because it's wierd, you just may have to find a smaller diesel. If money is no object, why not check out the mercedes diesels?
Quick Reply: Duramax in an F-Body
