69 Camaro swap
I think that I understand how to hook everything up once I drop it in, but what do I have to do to mount it. I have heard that I will need to buy some motor mounts and have the oil pan "notched". Are there any other things that I have to do to mount it in the car? Can it be mounted without dropping the oil pan and having it modified? How can I make it fit without paying someone to modify stuff for me?
After I drop it in what mods will I have to make for the accessories like power steering, alternator, AC, etc?
1969 camaro rs ss ls1 project
No way to install the LS1 without modifying the oil pan unless you ditch the factory steering setup and swap over to a front-mounted rack/pinion setup. BRP has a conversion kit for using 98-2002 f-body racks to fit your 69.
Tony
Stainless Works sells longtube headers to fit LS1s installed in 1st gen Camaros. They are also a site sponsor.
www.StainlessWorks.net
Tony
Tony
The way we positioned it, we are running a stock un-modified F-body pan, with stock steering. I would assume that my motor is sitting about 1" farther back than it would with the adapters.
Tom
www.ls1speed.com
Tom
www.ls1speed.com
If so, do you market the engine mounts? Thanks, Glenn
When we do conversions here, we have been fabricating them to give us the optimum engine placement. We may start using some of the bolt-in adapters in the future.
Tom-LS1 Speed Inc
LS1 LT1 F-body, Supercharged SVT,
LS6 LS1 C5 & Buick Turbo Performance
