3.8 conversion
Old Jan 26, 2008 | 04:04 PM
smokinbanditls1's Avatar
Default 3.8 conversion
i have an 98 camaro with 3.8l V6 and 700r4 tranny i'm looking to put an ls1 or 6.0 ls2 i need to know what i need for this swap i'm pretty sure that i'll need a tranny not sure which the guy i called from mr. goodwrench said that a t.a. wouldn't fit because the difference in the bellhousing i think i need an ecu and wiring harrness but don't know where to find them cheap does anyone make a kit for this conversion will the motor fit do i need to change suspension rearend this is my first project and my first time on a forum so any and all help would be greatly appreciate open for all oppinions thanx in advance
Old Jan 26, 2008 | 05:08 PM
jkwalkercchs's Avatar
hmmm im wanting to do this 2 u can buy a wiring harness on the forum some time but if u got money buy the painless
if u wanna make it fly by wire throttle body i got a harness i would get rid of if u are willing to buy it i think im just gonna wait my swap off
Old Jan 26, 2008 | 06:25 PM
youwilllose's Avatar
I just got done doing this to a 94 v6 camaro. You will need to get a different k- member, wiring harness, ecu, fuel pump and some other thing i cant remember right now ill think about it and let you know
Old Jan 26, 2008 | 08:26 PM
Default thanx
that be great if you could just p.m. or e-mail me it'd be a great help everyone tells me it's not worth it buy a new car but i own it and it's in good shape a ss goes for alot more than a new motor but anyways thanx alot man
Old Jan 26, 2008 | 08:30 PM
ok seriously i get where u are coming from like my v6 is a 1 owner so i wanna keep it for a long time i have memories in that car and when i sit in it i feel good like its tailored to me
Old Jan 26, 2008 | 10:15 PM
I here ya on everybody tellin you to buy a new car, but do what you want. I spent 1k on the car and dumped as much into it that a 02' would go for and now i have a paid for car that runs low low 9's.
If any of you have any questions just pm me its easier to remember that way then I can just think of what I did.
Old Feb 2, 2008 | 10:41 PM
so i think i might convert mine since the motor is locked up
can i just buy a tunular k member??
Old Feb 2, 2008 | 10:47 PM
95FbFormula's Avatar
Tubular k-members aren't really for DD use most people don't have a bad experience with them but some have them break. All you need the the center section not the lower/upper control arms most people are selling the center section for about $50 and the whole thing for $100 plus you need the mounts and stands also not very expensive to find used. And don't forget the ls1 steering rack and linkage.
Old Feb 2, 2008 | 10:49 PM
I use my tubular k member for DD never had one problem. Neither has anyone that I know.
Old Feb 2, 2008 | 11:20 PM
so i have a motor and a 5.3 fly by wire harness
a ls2 intake
90mm fbw throttle body
so should i do it??
