need some guidance for my conversion
Thanks, Clay
Do the wiring yourself. It is really not that hard, and since I did a 99 engine in my 70 corvette, I can help you with it.
I am running the stock 1970 tank with the feed on the bottom and the vent/return on the top. I picked up an inline Walbro 255LPH pump and mounted it to the frame rail on the passenger's side under the tank. In front of that is an off the shelf 99 Corvette fuel filter/ pressure regulator. A single fuel line then follows the old lines up the fuel rail.
If you have anymore questions, feel free to ask. Also check out my website.
Thanks, Clay
