Braided Steel Fuel Line
Not sure where your looking.
Personally I would find a local, industrial, hydraulic hose supplier.
Andrew
I got mine from Ebay but it's only rated to 55psi or something. I'm running carbed though. I was still planning on using it when i had orgionally planned on running EFI. I figured that since it was braided steel that 55psi was close enough. I bought it in a 25ft roll for like $60 shipped.
Those from Jeg's or Summit will be find.. Check with your local part or HP store.. they should carry SS Braided hose that you can buy by the Foot. But as stated above... you can check with a local shop that handles industrial / hydraulic hose and tubing supplys
It boggles the mind where people cut corners on their projects. For starters, you should not have more than 2-3 feet of flexible line in the whole car! Hardline is inexpensive, easy to work with and will last practically forever, unlike the eBay special, made in China, from god knows what, braided hose. After seeing what pump gas does to all makes of hose, I would use as little of it as needed. Teflon lines hose will not be effected by pump gas, but its not very flexible.
Andrew
Andrew
Andrew
Andrew
Andrew
Sometimes people sell stuff they didn't end up using, or bought too much of, etc, etc, etc.
Stop hating on eBay. You can find a lot of **** there for dirt cheap because someone doesn't need it anymore.
This is not to say that there aren't sub-par parts on there, but if you look at the seller its easy to tell if he's selling off his extra good parts vs selling cheapest crap he can get his hands on
/rant
Also, just because its on eBay, doesn't mean it from china.
/rant
/rant
Andrew
