ls1 Stand Alone Wiring Harness Diagram
#41
Stand alone harness
hi I wish to have the pin out did Diagrams to now what wires to remove so I can connect my 1999 ls1 to my 1975 model Holden hj ute. And all info reguarding the 4L60e transmission. Cheers
#43
Wire harness
so I just follow the Pin out diagram and what about the wires the say not used., once finished what wires should be left to connect the four wires I need to connect to my car. Cheers
#44
Wire harness
#45
Hi but my ls1 is from Australia and the wires might be in different pins . Is there any diagrams matching my car. Also I need to know which wires that solder together at the end like the starter motor, alternator ignition and 12 volt to battery constant. Cheers
#46
Ls1 standalone diagram
my email is glewis275@hotmail.com
#47
would you be able to send me the schematics to make a harnes please i need to make one as im putting a ls1 in my 74 oldsmobile
I need to know all the wires I need to remove from the pcm and which wires are left for me to connect to my starter , alternantor temp and oil sensor. And battery , ignition and grounds.
I would really appreciate any info. Cheers regards Many
Get Outlook for iOS
#49
#53
Hey I messed up and went ahead and pulled every wire from pcm connectors. Is there something that tells me which wires are terminated at connectors?
I have the pin outs from lt1swap.com. For instance Red connector pin 2 is brown TCC control solenoid..... Is that from the trans connector?
#54
#55
