Racetronix Walbro 255lph (in tank) pump (good to 600hp) and hotwire kit for sale!!!
This kit is brand new (not used) will work with e.f.i. g-body Monte Carlos, GN's, El Caminos, T-types...etc...
I originally bought this for my ls1 swap in my el camino but went a different direction for fueling the motor. I believe i originally purchased the whole kit for around $160 after taxes and shipping.
I will let the pump and the hotwire kit, which includes the relay and connection for the pump to run off of the alternator plus the BGK8S Battery Ground Upgrade.
$100 +shipping (~$8) to any of the lower 48 states.
Thanks,
-DeAndre
Thanks,
-DeAndre
im doin the same thing with my tank with the sump but after talkin to some friends of mine said ths sumped tank starves the motor under hard braking and the pumps not in the tank burn out alot ps what motor monts and oil pan did you use thanks
The fuel pump you want to get is the Magnafuel protuner 525pump (good to 1000hp and adj from 20 to 125psi) This pump is made for street duty and ihaven't read anything about them burning out! They are better than the aeromotive A1000 pumps which is made more for racing than for a street application. Do some research on the Magnafuel pump and see what you find.
You can also ask Newera performance what is the best inline pump for you to get and they will say the magnafuel is perfect.
Good luck with your build man...let me know when you start wrenching away.
...by the way, the racetronix kit is sold just in case anyone reads this thread and ar interested in buying it
