6.0 Malibu Wagon
Old 03-10-2008, 05:52 PM
lsxmalibu's Avatar
Default 6.0 Malibu Wagon..track time
a few pics of my project, 1983 malibu wagon, 2005 6.0, edelbrock cam and headers, Zex kit, 8.5" GN rear, th350, 10" converter. I had a carb kit on it last year but needed a new MSD box, I found the FI parts would be cheaper so decided to try that route. Luckily My brother does computer tuning (jay_lt4) so he did my program and cut down a factory harness.
rao
rao's Avatar
Nice!
Old 03-10-2008, 06:40 PM
Cool_Hand_Luke's Avatar
Looks good.
Post up some more pics and some vids of that wagon in action.
Old 03-10-2008, 06:56 PM
944nate's Avatar
sweet ride im doin a similar swap this summer in a grand national body i have sitting around.i was wondering if the lsx series bolted to older trannys i guess so, how about the motor mounts?
Old 03-10-2008, 07:25 PM
lsxmalibu's Avatar
they sell conversion mounts, I used the s-10 lsx mounts.
Its winter here, I havent had it on the road yet, here it is running. With the carb it had a real loppy idle, with the FI it purrs.
http://smg.photobucket.com/albums/v2...=Picture-1.flv
Old 03-10-2008, 08:17 PM
flywheel's Avatar
What are the specs on the Edel. cam? It sounded sweet....- Was that the lq4 or the lq9 motor?
Rick
Old 03-10-2008, 08:48 PM
deeloc1's Avatar
Sweet!!! I have a new motivation to finish my elky swap! Are those edelbrock longtube headers? If so, did they bolt right up without mods to the s-10 motor mounts or the headers?
Old 03-10-2008, 09:14 PM
markarleta1's Avatar
Default your hoses
what kind of car did your radiator hoses come from? do you have the part numbers?
Old 03-10-2008, 09:22 PM
lsxmalibu's Avatar
Rick
lq4
Duration @ .050'' 230° Intake/237° Exhaust
Lift @ Valve .540'' Intake/.540'' Exhaust
Old 03-10-2008, 09:23 PM
lsxmalibu's Avatar
upper is a stock 99+ silverado
lower is a stock malibu with v8
Old 03-10-2008, 09:24 PM
lsxmalibu's Avatar
they are edelbrock shorty headers for a ls1 firebird-camaro, bolted right up.
Old 03-10-2008, 09:38 PM
LSfan70s's Avatar
Very nice. Sounds great!
Old 03-11-2008, 06:49 AM
forcd ind's Avatar
LS1Tech 10 Year
pretty cool-that style body is pretty popular now, wish i didnt have slow dial up so i could see vid's, lol
a buddy of mine is sticking an lq9 in one to go bracket racing, i'll pass on some of the info to him
Old 03-11-2008, 09:10 AM
bczee's Avatar
Great job.. how about some more pictures..!
Old 03-11-2008, 09:43 AM
monteperformance's Avatar
Were you able to hook up the kick-down cable on the Turbo 350? I thought 2005 motors had the drive by wire throttle body?
Old 03-11-2008, 10:00 AM
colby72olds's Avatar
that's sweet
Old 03-11-2008, 10:17 AM
lsxmalibu's Avatar
I dont run a kickdown. The motor was out of a 2005, but I used the FI off a 2002, so its cable.
Old 07-17-2008, 07:22 AM
lsxmalibu's Avatar
Originally Posted by Cool_Hand_Luke
Looks good.
first dyno run
this is a stock truck 75mm TB-intake, small .540" cam, headers , zex ( only added 80hp at the wheels ??) 2.5" cheap thrush turbo mufflers. max timing was locked out at 24 degrees. untuned and very rich, shut it down at 6000 rpm.
Old 07-17-2008, 08:06 AM
FoggyStyle's Avatar
Nice job! I see you used the S-10 mounts. How were the oil pan clearances? Did you use the truck pan? I'm putting a 2000 5.3 in my G-body (Monte Carlo), and I think I'll use the H3 pan. A lot of S-10 parts can be used on G-bodies, so I'll bet a lot of those conversion parts will fit as well.
Old 07-17-2008, 08:12 AM
lsxmalibu's Avatar
my motor is set all the way back to the firewall. Stock truck pan clears fine, but does sit about 2" below the crossmember, but there is still 5" ground clearance.
Quick Reply: 6.0 Malibu Wagon
