What does your swap weigh/run? What about mine?
shawn- update on that 6010 box- got it and it worked a treat, very easy to set up. i ended up with something like 15deg timing initial, to about 29-30 deg from 3000-6400rpm. no pinking or problems at all. wished i had gone for that msd box first time round, fired up first go. car made 412bhp@ hubs and 390ft/lb today! :-)
yes its factory heads and bottom end, and a small cam. i have a set of full race headers and 3" exhausts on, plus its lost all the accessories etc and is dry sumped. the msd box seems to be good value for money, it even came with the serial lead and a wiring loom. i used the vac/map sensor i already had to sort out the timing at idle/part throttle.
cheers
cheers
its running an alternator and water pump driven by a 6 rib belt off the crank pulley. the dry sump scavenge has its own small drive belt also off that. i run stock ls1 tensioners for the drive belt. seems to work ok so far.
My car is soon to get a weight test... Its an S13 (Canadian) With ABS Full Interior (no belt mechanism) VLSD, Super-Hicas Steering and a Stock Factory Side Skirt... (different than all the others i've seen) with a Sun Roof... has an LS1 with the Auto Tranny... 1 or 2 weeks hopefully and i'll give it a weight check...
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
My build right here..
https://ls1tech.com/forums/conversions-swaps/823536-yup-another-mustang-ls2-drag-car.html
90LX, LS2, TH350 - should weigh 2850 with me in it. I have to put 350lbs in it for the class I am running.
I really want to put a stick in it, but my finances say otherwise.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
I weighed in at 1700 lbs with about 4 gallons of fuel and no driver on my Lotus 7 replica.
I've done some major frame mods this year, some of which add weight (SCCA roll bar), a number of others that reduce weight, and major shifting of weight towards the rear (moved engine, tranny, driver, passenger, and roll structure 4" back, moved battery to the rear, etc... Crossing fingers for 1600, but don't know if I'll get there.
#34
well not very impressive times here yet, my LS2 63 Biscayne is around 4000lbs and best time so far is 14.3 @ 95, thats with 3.08 gears and one wheel spinning , had to feather the throttle all the way through first gear, floor it in 2nd still with some wheel slip, got some 3.55's and an eaton posi ready to install when i get time then i'm hoping for mid 13's.......
#37
In stock form my 48 Chevy Coupe curb weight according to the specs was 3200lbs, replacement of lighter engine, rear suspension and front suspension should put me about 2900-3000lbs. The car is still in progress of being put together. I am hoping between 375-400rwhp with mods done on engine, 3200 stall and 373 gearing with an A4.
#38
I think my car has a factory curb weight of 3440. with the lighter LS1 engine probably has a curb weight of 3300 lbs. It has 3.08 non posi rear. I can't launch hard but with a slight roll out it hooks fairly good. I'm not sure how quick the 1/4 times will be but it went 0 to 80 in about 9 seconds on it's day view run.
https://ls1tech.com/forums/showthrea...844&highlight=
#40
my car is about to be done, I need a starter and a dipstick for my tranny which isn't available in lebanon (middle east) when thats done im going to go or a weight measure... and i'll reply...
