Isuzu Amigo swap
Jim C.
I went to a huge swap meet last month, and a guy had a lowered, tubbed out suzuki samurai with a BBC in it, had to be the coolest thing I have ever seen. The Amigo would be a cool conversation piece if nothing else.
Jack
Did not have spark so changed the Crankshaft sensor.Now I have spark but still does not start.Had the injectors cleaned and check and still does not start.I am using a Howell harness and ECM but don't know what else to do.The guys at Howell say it must work.Well it doesn't start.Does anyone have any ideas.After all the trouble this is not something I wil do anytime soon.Must say you guys in States know how to do these type of projects.You have everything at your disposal.
Some pics of the car:
Every thing is standard LS1 stuff.It is our of a corvette.The transmission is a 5 speed.It is the standard one that was in the truck.They are pretty strong and if I break it,then I will change it.
I have lifted the body 2" so the hood clearance is not an issue.Had to modify the original bell housing to mate with the LS1.I also had to change he clutch from a Pull clucth to a Push clutch.
The radiator that I used is from a(hate to say this) 740 BMW.Also changed the fans as my original V6 had a viscous fan and now fitted 2 electric fans.
As for motor mounts,used the LS1 mounts just had to modify the chasis mounts to mate with the LS1 motor mounts.
I have to admit,this is a very tight fit.
I can't wait to get this damn thing started and race around with it.It is a 4x4 and I am keeping it 4x4.
It's a hell of a tight fit!!!!!Will have to pull the motor if something goes wrong with the aircon compressor.Then I will have to go and have the ECM re-done as no one here can get into the Howell software to tweak it and if something goes wrong,they cannot get into the ECM to check fault codes either
Have had all the wiring sorted out as well so everything comes on and goes off like it should.
Have had to get different diffs for i as the original ones are a bit small(not very strong) and I cannot go down on the ratio if necessary.I am putting a 3.727:1 ratio and if necessary can still go down to 3.55:1.
After that I am fittng a 3" lift Calmini suspension upgrade.And hopefully that's all????
A few photo's of the vehicle.
Your truck looks absolutely awesome. Good luck with it and please keep us posted. As soon as I get back on mine I will post up my progress. In the mean time I keep pimpin the pink monster (The Amigo you pervs!!!!).
I am busy with the diff and it is a bigger/stronger diff than my original.
Here are a few pics of the diff,had to machine the ends off as I am also fitting discs on the rear.
Thanks OMC8
