ABS Brake Module Needs VSS Input-Where From?
Old Apr 4, 2008 | 09:59 AM
LS1GMCTruck's Avatar
Default ABS Brake Module Needs VSS Input-Where From?
Have Wait4Me Computer & Harness as a stand-alone LS1/4l60E installation. Only wire(white) not connected to my ABS Module, and that is required to function, is a VSS input. There is no provision for this on my harness, other than a VSS output for the speedometer function. Any idea where I could pull another VSS output from? Many thanks...
Old Apr 4, 2008 | 10:29 AM
91parkave's Avatar
Moderator
you should be able to tee the wire with your speedometer input
Old Apr 6, 2008 | 08:54 PM
Default Really?
O.K. Thanks
Old Apr 7, 2008 | 09:12 AM
01WS6/tamu's Avatar
You need to find a pin out for a ls equipped fullsize truck. I am not at work today but can get you a diagram tomorrow. The abs uses what is called a high resolution speed signal input from the pcm. That is the pin you need I am just not sure what connector or location off the top of my head. It is a yellow with black tracer out of the pcm.
Old Apr 7, 2008 | 02:01 PM
Thumbs up VSS Signal Wire For ABS Module
Man, That would be excellent if you could get that from the diagram! I need to mention that I have a 2001 F-Body computer, don't know if that makes a difference or not, versus the truck computer. You really know and understand this LS1 computer ****! It does'nt come that easy for me. Thanks.
Old Apr 8, 2008 | 12:39 AM
01WS6/tamu's Avatar
Yep the fbody computer has this output also. I am doing the same thing on my s10 and needed the same rear speed signal for the abs. I'm using 02 fbody computer and operating system
Old Apr 8, 2008 | 02:10 AM
Kamin's Avatar
are the VSS signals the same between the different generations of vehicles? cause if they are different your ABS could **** itself lol
Old Apr 9, 2008 | 11:46 PM
01WS6/tamu's Avatar
The VSS signal is the same for the abs. It is different than the speedometer though. The pin you need for the high res rear speed signal is pin 49 in the red pcm connector pack. I have done this swap before and used this signal and the abs functioned perfectly.
Old Apr 11, 2008 | 09:23 AM
Thumbs up
Thank-You Sir!
Old Apr 11, 2008 | 11:53 AM
andrew69_04's Avatar
HA sweet. Thats good to know. ever since i swaped in my ls1 into my s10 my abs an brake light are on and i coulfn't figure out why....now i know why!
Thanks 01WS6/tamu....now i can get a few dash lights shut off!!
Old Apr 11, 2008 | 12:12 PM
I just checked my truck out. I have the yellow and black wire that goes to the ABS module. Pin 49 is not used on my 2002 LS1 ECM. If i put my own pin in the spot it should work, correct?
Old Apr 11, 2008 | 03:43 PM
01WS6/tamu's Avatar
It will work correctly if you hook it up. The ls1 f-bodies did not use it because they have individual rear wheel speed sensors that tie directly into the ABS module.
