Finally figured out Alternator wiring!
#42
ok so i tried wiring the alternator as the first post explained. resistor and all. didnt work. removed the one wire and just used the resistor on pin c of the alt. still not working. swapped the pins so the resistor was on pin b. still nothing. both were going to switched power on my fuse block(aftermarket) and im running a holley efi. its a 5.3 with the 5.3 alt. took the alt to get tested and rested good. took the resistor out of the circuit and put in a 194 plate light socket and still nothing. i have power at both pin on the pigtail for the alt. ay help would be great. thanks in advance
#43
You should have key-on 12v power to one side of the bulb/resistor, the other side goes to the alt. terminal. When you turn the key, 12v goes thru the bulb/resistor to excite the alt. until it's putting out voltage. When that happens, voltage equalizes between the bulb/resistor, current flow ceases, and the bulb goes out.
#44
OK from everything I have read on here, on a F-body alternator pin B on the 4 wire plug should have a 12v source with a 470ohm 1/2 watt resistor inline in order to "turn on" the alternator. Well I tried that and it didnt work. Got a new alternator same thing. So last night in frustration I decided to leave the wire and resistor where it was and put 12v to pin C and BINGO! Alternator started charging and the gauge went to 14 volts.
So in my expirience, pin B needs the 12v w/470ohm resistor and pin c needs 12v in order for the alternator to energize.
This was a carb'd setup using a '98 camaro alternator (even though autozone only had one part number for 98-02 f-bodies)
