A few questions (harness, bHousing)...
I have an LS1 from a '99 AT camaro.
Wiring: how much can I delete?
I am going to delete the wiring suggested in Jon Rodder's Guide. There are also other several other wires I would like to delete from the PCM:
A/C: R14, R17, R18, R43; B45
AT : R6, R8, R47, R48, R51, R63; B17, B18, B53, B79
EGR: R7, R41; B41, B47, B55
VSS: R20, R50
I would like to delete all of the automatic transmission wires to the PCM. I believe that the only thing I need off the T56 is the reverse lights. I got a pigtail for that switch and will wire it into my swap vehicle myself.
Bellhousing Dust Shield?
I got my motor and transmission separately. The motor and transmission are mated right now. The engine side of the bellhousing is bigger than the engine on each side. Creating a hole on each side.
Is there supposed to be some type of shield to cover these holes? I know the starter will cover some of the passenger side hole...
Thanks,
-C
VSS: R20, R50
Thanks,
-C
The reverse lockout on the T56 is nice to have too.
The PCM uses VSS for a ton of stuff. You can get it to run without a VSS, but it's a whole lot smoother on the street if you have VSS.
I have a few more idiot questions, for this thread.
I could find a definitive answers anywhere else, so here I go.
Alternator Positive Lead
I'm not sure were the positive lead goes on the alternator. This is what mine looks like right now. The black, ground wire is hooked up to what looks like what should be the positive lead connection. Then the ground would hook up to another bolt on the casing of the alt?
This is the way my motor came, so i was unsure.
One more.
There is a breather coming off my T56. Do I need to hook it up to anyhing, or do I just leave the plug over it.....
One more.
That is not a ground. It is your positive lead. it goes directly to a positive terminal block . There is only one more small wire that is in the pcm harness that connects to the alt.
on my e30 i was going to go through and sort wires out but its kinda a PITA, so i just kept them in there, and just had them deleted. Mine also, and i think all BMWs take the speedo from the diff. Im having issues right now for some reason with mine staying in limp mode??
Thanks for all the help. These are all basic questions, but I don't want to screw up...
Just to clarify one more time (sorry)...
The positive lead attaches to the circled post?:
I was thrown off when my motor came with a black ground wire and rubber cover connected to the positive post.
The only other question I have is about the line coming off the T56, I have no idea what to do with that....?
Thanks again!
Thanks again!
The black wire is NOT a ground wire. It is a hot wire that charges the battery. The red wire goes from the battery to the red capped terminal on the fuse block located on the left front inner fender. This wire powers the car through the fuse block. Both of these wires originate at the positive battery cable where it attaches to the battery. If you connect either one of these to ground, you will have an early Fourth of July. Hope this helps.
I wasn't going to attach the charging wire to ground, just was confused that it was black.
I have everything else in the car wired up. I'll run the black charge wire to the battery and be done.
