Someone with the 5.3 Vortec. HELP FAST!
Old Apr 17, 2008 | 10:24 AM
miller456's Avatar
Default Someone with the 5.3 Vortec. HELP FAST!
need to figure out which wire goes were on the CKP, (crankshaft position sensor). the clip on the harness has been cut off, and need to just know where each wire go on the sensor.
should be like 3 wires?? yellow, blue, green.
Thanks!!
Old Apr 17, 2008 | 11:03 AM
lt4malibu's Avatar
i looked it up for a 2001, says dark blue is for a sensor signal not light blue, lemme know the year and ill check to make sure.
Pin
Wire Color
Circuit No.
Function
A
DK BLU /WHT
1869
CKP Sensor Signal
B
YEL
1868
Low Reference
C
LT GRN
1867
12 Volt Reference
Old Apr 17, 2008 | 11:19 AM
miller456's Avatar
its for a 2001. the wires seem right then that you came up with. but i think my wires are solids no lines? oh well im sure there the same, but does the A, B, C, tell were each wire goes on the crank sensor itself or what?? is the sensor labeld like that? i havent taken it off the block. i have to know where each plugs in on the crank sensor. thanks
Old Apr 17, 2008 | 12:09 PM
lt4malibu's Avatar
yes the connector is marked A,B, and C
Old Apr 17, 2008 | 12:29 PM
miller456's Avatar
thank you!! i got it! now i just need to order a clip
Old Apr 18, 2008 | 10:59 PM
miller456's Avatar
hey lt4malibu..... could you do a couple more for me??
Cam sensor, and MAP sensor. thanks!
or better yet.... do you have them all?
thanks!!!
Old Apr 18, 2008 | 11:11 PM
G-Body's Avatar
sawzall wielding director
Heres a link to a lot of the pinouts and wiring diagrams https://ls1tech.com/forums/showthrea...iagrams+wiring
Old Apr 18, 2008 | 11:51 PM
miller456's Avatar
yea i have those pinouts. but i have a few connectors that have been cut off my swap harness, and need to know which wire goes were to the sensor itself.
Old Apr 19, 2008 | 12:36 PM
lt4malibu's Avatar
PM me your email, ill send you the connector pictures and everything.
Old Apr 19, 2008 | 05:16 PM
miller456's Avatar
PM'd you!!!!!!
