Ls1 fox swap come in need help?????????????????????
Old Apr 26, 2008 | 04:02 AM
LS1SS4ever's Avatar
Exclamation Ls1 fox swap come in need help?????????????????????
I have QA1 k-member 5.0 which mount should I use? 4.6 Or 5.0? Will it fit direct to k-member or need to put more spacer between k-member and the mount?
Old Apr 26, 2008 | 07:40 PM
dman's Avatar
damn, i have the same car... i used 4.6 mounts but made plates that go between the mount and motor that allowed me to set the engine back 1"..
Old Apr 27, 2008 | 02:45 AM
LS1SS4ever's Avatar
Could u post some pic to get the idea??
Old Apr 28, 2008 | 09:56 AM
dman's Avatar
not sure if you can see real well. i'll get some better lics of just the adapter plate
Attached Thumbnails Ls1 fox swap come in need help?????????????????????-ls-swap-008.jpg
Old Apr 28, 2008 | 09:58 AM
dman's Avatar
BTW here's a pic of the car with it's turbocharged 5.0 motor and a 5 speed.
Attached Thumbnails Ls1 fox swap come in need help?????????????????????-darin1.jpg
Old Apr 28, 2008 | 10:19 AM
LS1SS4ever's Avatar
Thax for pic but not clear
Old Apr 29, 2008 | 12:44 PM
dman's Avatar
it's just a flat plate of 1/2" thick aluminum thats roughly 9" wide X 4.50" tall that bolts to the engine where the LS motor mounts go. Then i bolted 4.6 mounts to the plate. If you look at the pic closely you can see the aluminum plate sandwiched between the engine and motor mount
Old Apr 30, 2008 | 02:43 AM
LS1SS4ever's Avatar
I get the idea, but it will be clear more if u post clear pic thx for more detail.
Old May 3, 2008 | 12:50 PM
dman's Avatar
here is a pic of the adapter plate, the studs sticking thru are to attach the mount
Attached Thumbnails Ls1 fox swap come in need help?????????????????????-motor-mount.jpg
Old May 3, 2008 | 04:00 PM
whiteLS1's Avatar
that was a good idea i like it. i really want to do one of these swaps soon.
Old May 4, 2008 | 04:20 AM
LS1SS4ever's Avatar
That’s great and safer instant of cut 4.6 mount
