4L80E tailshaft damage due to wrong cooler fitting!
ATI trans sells some AN fittings for the trans, not sure if a 90 deg hose end would clear the trans tunnel
Forgot to mention this. I do think forcd ind is correct in that the fittings are straight thread and not an. I used 90 an and didnt get crazy screwing them in. I also made sure to used the teflon paste sealer on everything.
The factory line are "similar" to a fuel line, quick disconnect.
To run braided line and an fittings you will need two 90 degree -6 fittings that are 3/8"? to -6 and the line itself. You will need to drill out the fitting used for the rear with a machinist bit and press in a tube of the proper length. I did this and measured off of the factory fitting.
In case anyone is interested the part numbers are as follows.
15773661 cooler line approx $26
15809053 cooler line approx $31
24205103 retainer approx $3.25
http://www.jegs.com/i/JEGS/555/100550/10002/-1
thx
