Header Flange
Old Jun 3, 2008 | 01:07 PM
lowdeuce's Avatar
Default Header Flange
Well I am to the exhaust portion of my install of a 6.0L in a stock front clip 1966 Chevy II. I need to order a set of header flanges and I was just wondering what brand of flanges do you guys get? I see that GM offers a header flange in 1 3/4 ( part #12480130 ), but I also noticed that patriot exhaust also offers a flange kit. They only thing that I don't get about patriots is they list the flange in three sizes 1 5/8 - 1 7/8 with the same part number. Has anyone used the patriot header flange before? Just checking out what options I have before I order.
Thanks,
Jared
Old Jun 3, 2008 | 01:27 PM
76LQ9TA's Avatar
I have an extra GM flange I can sell you for $25 plus shipping. It is brand new in the original box. If you need any measurements off of it to compare to the patriot flanges I can get those for you too.
Old Jun 3, 2008 | 04:16 PM
lowdeuce's Avatar
I searched the GM flange and came up with some measurements, I believe they are 3/8ths thick and have a primary size of 1 3/4. Does that match the measurements of the GM flange that you have 76LQ9TA?
Thanks for the fast response,
Jared
Old Jun 4, 2008 | 09:04 AM
ssduane's Avatar
http://www.speedwaymotors.com/p/6766...tml?itemNo=LS1
Old Jun 4, 2008 | 02:49 PM
yecker's Avatar
Wow those are only 5/16" thick. Thinnest I had seen before was 3/8".
Old Jun 5, 2008 | 09:51 PM
JeepinBash's Avatar
sorry for the hi-jack but i feel like this is really relevant to the OP. what is a good source for header tubing?
Old Jun 5, 2008 | 10:35 PM
Jeff64's Avatar
Default Headers
Lowdeuce-
I'm getting ready to start the same swap, but in a 64 II. My biggest concern has been headers. I'm going to do a rack and pinion conversion to free up some space, and am hopeful that a set of headers from S&S Headers http://www.ssheaders.com/muscle.htm (#5207) might fit. I spoke to the tech guy there, and he indicated that they will several cars with R&P conversion, maybe even a stock front clip! He said that these headers really hug the block, so I've decided to order a set when I'm ready, and try them out. I was told if they are not dinged up, I can return them.
Not sure if you have done this conversion, but it may be worth a shot if you don't have to build headers.
-Jeff
Old Jun 5, 2008 | 10:51 PM
Lason's Avatar
I found a guy on theturbofoums.com to cut me out a set of 1/2" thick flanges for my turbo headers. $50 for the pair too, you cant beat that!
His screen name on there is "Yecker"
Old Jun 7, 2008 | 09:31 PM
63chevyll's Avatar
Default headers
I modified my old fender well headers, I used only 2 new tubes, all the other tube are the pieces I cut off the old flanges. I used the GM flanges they're nice. Here's a pic of my junk.
Old Jun 7, 2008 | 11:05 PM
V8Rumble's Avatar
Good to hear! I'm going to be doing much the same thing with my project, I sure wouldn't complain if you felt like posting a picture that focused on the flange...
Old Jun 8, 2008 | 08:34 AM
protrax's Avatar
Yeah This is the thread I have been waiting for ! I have a 67 chevy II I am doing an LS6 swap into with the stock clip on it as well , What oil pan did you guys use on your cars ?
my plans are the cut up my fenderwell headers like 63chevyII did. Can you post more pics I would love to see more
Old Jun 8, 2008 | 08:21 PM
63chevyll's Avatar
Default pics
I didn't take a bunch of good pics. This headers are over 12 years old and really thin thats why I didn't grind the welds down. I recommend using new headers.
Old Jun 9, 2008 | 01:39 AM
babydeuce's Avatar
Stock clip car, run the GTO pan, it clears everything nicely......
Jack
Old Jun 9, 2008 | 05:10 AM
protrax's Avatar
Awesome
Thanks guys!
Old Jun 9, 2008 | 07:16 AM
lowdeuce's Avatar
Has anyone looked into the 351W swap headers used on early mustangs, since the front clip is basically the same design as a Chevy II front end? I believe the deck height of a 351W is very similar to the deck height of an LS1. Might be another option for headers on a stock front clip.
Jared
Old Jun 9, 2008 | 11:07 AM
Zedzag's Avatar
I've got a pair of the GM flanges if anyone's interested.
Old Jun 9, 2008 | 09:32 PM
63chevyll's Avatar
if you use the stock clip, #2 & 4 cylinders need 90 degree tubes with 1 3/4" radius. The GTO oil pan works perfect. S & P has them cheap.
Old Jun 9, 2008 | 09:54 PM
V8Rumble's Avatar
Kudos to you 63chevyll - it looks like you did a really nice job there... And that first picture you posted (that shows the thickness of the flange) is just what I was looking for - thank you! Good luck w/ the rest of the project.
Zedzag - I'd be interested in the pair you have, if I thought that shipping them to me (here in the US) wouldn't cost more than my simply buying them new... Here's a bump hoping that you get a quick sale.
Old Jun 10, 2008 | 08:16 PM
protrax's Avatar
Very nice job ! this is really going to help me alot , I will post picks of my 67 as I get going in the next couple weeks
Thanks for the pics and info , I can't wait to drive it again
Old Jun 14, 2008 | 08:03 AM
protrax's Avatar
well guys I tried to fit my Ls6 in the nova last night, my corvette batwing pan is definitelly not going to work! I need to find the GTO pan and you have suggested.
where can I find s &p
