Functional Shaker Scoop on 2nd Gen TA
![](http://i73.photobucket.com/albums/i237/76LQ9TA/DSCF1653.jpg)
I finished the mold last weekend and started to lay the fiberglass. I need to add some nuts on the inside for mounting to the engine, lay one more layer of fiberglass and then spray on the gel coat. I may also try to eliminate the third elbow to reduce some of the restriction in the air flow. Currently I have two 4" 90's and and a 4" 68 degree elbow.
Good going, I fab'd up a X Brace that used the four Fuel Rail bolts and the EGR bolt to to secure my air box. Then just used one long carb bolt to secure my air filter.
http://i190.photobucket.com/albums/z...c/DCP_3870.jpg
