1st gen camaro update and question
Old Jun 9, 2008 | 01:41 PM
Rhino's Avatar
Many people put it where the glove box would normally be. I intend to extend my harness a little and place it under the dash, housed within a custom console.
Old Jun 9, 2008 | 07:34 PM
67LS3's Avatar
looks like you used the a/c bracket that i got from e-bay. seems like a very quality part. where are you going through the firewall with your harness when you relocate it?
Old Jun 10, 2008 | 09:52 AM
Rodder's Avatar
Right now I'm thinking I'll go through the VA firewall filler panel, right above the bottom/middle bolt.
The kwikperf bracket gets a thumbs up from me. When I saw all the spacers I though it was going to be a pain in the butt to bolt together, but it turned out to be really simple and straight forward, and didn't even require a 3rd hand. I have a thread going on Team Camaro with notes on my VA GEN-IV install including the kwikperf brackets: http://www.camaros.net/forums/showthread.php?t=133176
Here are my notes from the kwikperf brackets:
- re-read the whole instruction sheet, both sides, right before you start
- remove the pulley from the LS1 tensioner before you remove the tensioner from the water pump
- when they say to leave all of the bolts loose until it is *all* bolted together, they mean it. If you tighethen any, you will be loosening them before the last bolt is in.
- double-check that you aren't forgetting a spacer before you screw in each bolt
- Use antisieze on the bolts that thread into the aluminum head and water pump
- Leave the new pulley off of the tensioner until after you have torqued the bottom tensioner bolt, otherwise you can't get a socket on the bottom bolt.
- If you mounted the LS1 PCM to the fender, it's probably not going fit with the compressor installed unless you move it farther back. And if you move it farther back, you'll probably need to move it down so that the hood henge doesn't hit it.
Old Jun 14, 2008 | 09:34 PM
67LS3's Avatar
please post pics of how you mounted the late model f-boby lt1 or ls1 radiator to the 1st gen radiator support. the late model rad doesnt look to have any mounting brackets. how did you guys do it. i am seeing a lot of zip ties....also is there a difference between the factory lt1 fans and ls1 fans? are the v6 fans different? just being sure so i get the right fans. anybody have a ls1 fan setup?
Old Jun 14, 2008 | 10:53 PM
jmdale1984's Avatar
The LS1 and LT1 fans are a little different. However, they will both fit either radiator, and both will plug into either wiring harness.
I can check with my friend, I think he has some LT1 fans left over from a swap. Let me know if you need me to.
I have no clue about V6 fans. I don't think I've even seen under the hood of a V6 4th Gen.
Old Jun 14, 2008 | 11:55 PM
Shawn MacAnanny's Avatar
94 Z28 Radaitor and fans in 68 firebird. Ran a self tapper through the top flange of the radiator than the top flange of the fans. The bottom i made a 90* bracket and self tapped the bottom radiator flange to the bracket to the air dam. I can push the car by holding on to the top of the radiator so i know its not going anywhere.
Old Jun 15, 2008 | 09:58 AM
SurlyJoe's Avatar
I used the factory ls1 rubber radiator mounts. They have 2 rubber tips that I drilled holes in the lower rad support for them. For the top I used a flat piece of aluminum sheet and put the holes for the rubber mounts. It turned out very solid. Pics to follow.
Old Jun 15, 2008 | 07:48 PM
67LS3's Avatar
some pics would be great. also ..where did you get the radiator mounts? salvage yard?
Old Jun 16, 2008 | 09:51 AM
chrisp3's Avatar
okay next question. where did you guys put the ecm? i would like to get it inside the car. if inside, how did you route the harness through the firewall?
Old Jun 16, 2008 | 05:11 PM
SurlyJoe's Avatar
I got the rubber mounts from my 94 fleetwood parts car. I think a lot of the newer gm's might use the same rad mounts so wrecker would be the place. Here are some pics of what I did kind of hard to show the bottom part but I just lined the rad up and drilled holes. For the top it is a piece of aluminum from work. Height worked out bang on.
Attached Thumbnails 1st gen camaro update and question-dsc03258.jpg   1st gen camaro update and question-dsc03256.jpg
