LSx into Jet Boat??
https://ls1tech.com/forums/vehicle-c...5-avenger.html
. I may be swapping a LS into my jetboat sooner than I thought as I am already having problems with the 400 sbc I just put in.As for the steering wheel its a performance boat thing. Most production mainstream boats have the wheel on the right side so that its easier to dock with only the driver in the boat. The smaller volume custom performance boat builders usually put the wheel on the left side cause they couldn`t care less about docking and with a propeller driven boat putting the driver to the left helps to cancel out the prop torque, plus he is also closer to the center of the waterway that way.
......ANDDDD they usually have a gas pedal.It would be a little difficult to mount a foot throttle on the right hand side of the boat
You gonna swap the Sunsation or leave it alone until it has a bad day?
Ha ha - just kidding...
Then there were the 50-60s chris crafts with the front take off inboards where they put the driver on the left, but that's probably more info than you want...
Worked on the boat a little more last weekend. 1997 Ski Centurion with a 5.3, Z06 cam/springs, ported TB. Running Marine Power exhaust manifolds/risers. I have a hookup on the Marine Power stuff.
Getting there. Still working on wiring harness, coil pack relocation, belt routing, and other stuff.
The raw water pump is from Crusader. Bolted right up and included a serpentine large diameter pulley. We cut the lower part of the stock truck alternator mount with a band saw so the raw water pump would bolt up. The portion we removed would normally hold the P/S pump for the truck. It is not needed and is still well braced with just the upper half of it.
If anyone has a well priced TVS1900 or 2300 series supercharger..... please ping me
This boat also had trim tabs added and a self contained hydraulic steering setup from the previous owner. It came with a 350.... then he commissioned a 502 to be installed.... I finally bought it with no motor and all the goodies on it with the intention of doing an LSx swap.
Anyway, I'm wanting to go back to EFI - but I wasn't sure how to do the fuel system with twin tanks. I'm wondering if I can just Y for the feed and return; or if that's a no-no. The feed and return remote selector is like ~$550.
On a side note - did you modify your own harness; or just buy one? Also, did you keep the factory water temp and oil pressure senders; or is that info the computer doesn't need?
anyway had another BBC in the boat.. but now its broke.
So i found some PCM 6.0 exhaust manifolds with risers on ebay, and picked those up.
now im just looking to find a good buy on a LS LQ4 6 liter.. any suggestions ?
Plan to keep the engine simple, just a Cam install id like to keep iot EFI, but i need someone to tune it.
Help there would really help.
Any help on what would be a Good Cam for this na..
might look for some 243 heads to up comp too..
Thanks
So have to go pick it up next weekend friday,
the PCM manifolds are shipped prolly here mon-wed
Gotta figure out what CAM i need to run
Ordered LS6 Yellow Springs. there Shipped
pictures soon
Its gonna be a stock 5.3, going in a jet boat.
I plan to keep the Truck intake to help with low end torque.
will be EFI, stock internals, LS6 yellow springs RPM range would prolly be limited to around 5k due to the hp tq numbers, could maybe switch impellers to get more RMP
Would like it to build torque around 1500rpm and peak around 4k 4.5k.
exhaust will be water cooled manifolds to 3" tubes out the back
Last thing the cam for this na, build how turbo friendly would it be, i plan to upgrade to a turbo next year., and wouod like to not have to buy another cam then.
Thanks
