Anybody have a GM partnumbers for 98-02 Fbody accesorys?
As title says , does anybody have a GM part numbers for 98-2002 Fbody alternator , lalt brackets , ps pump +brackets+ reservoir ,tensioner etc.
I didn't use some of the bolts, but I didn't document which ones:
1 12555693 BRACE-P/S PUMP FRT
1 12556915 BRACKET-GEN RR
1 12559885 P/S PUMP PULLEY
1 12561584 P/S PUMP BRACKET
1 12563327 ALTERNATOR BRACKET
1 26068934 RESERVOIR
1 12569527 BELT 2001mm 6 rib
1 12560344 TENSIONER
1 26075068 P/S GEAR INLET HOSE
1 88985227 PUMP REM
1 12563326 IDLER PULLEY
1 11509666 BOLT
4 11515757 BOLT
1 11515767 BOLT/SCRW
3 11515767 BOLT/SCRW
2 11515768 BOLT-METR
1 11516356 BOLT/SCRW
1 88985227 PUMP REM
1 11509666 BOLT
4 11515757 BOLT
Thank you 69LT1Bird!!!!!
I found this for the alternator : Delco 10480308, 342, 343
Do you have any idea is teh 343 just latest partnumber ? Or what are the differences ?
