pics of my 6.0 swap to 70 chevelle
Old 01-06-2009, 04:00 PM
  #61
chevellepowered's Avatar
come to find out its a 4.8 has flat top pistons....hahahaha.. that sucks.. but that power for that is not that bad.. it was a fast lil burger,, very surprise,, still has cross haches in it..very clean motor.. what a waste.. owell.. im looking at a 5.3 $150 short block junkyard motor,, or a ls1 for trade stuff i have.. i'll let yall kno whats going in it!!.. wish it was l92 headed, ls2..haha
Old 01-06-2009, 04:31 PM
  #62
stealth71's Avatar
I have a set of 241 heads laying around if you're interested. No bottom end parts though.
Old 01-06-2009, 04:50 PM
  #63
thanks stealth..but i have set of 853 3 angle valve job with duel springs.. ive been using,, i looked at my injectors and they are dirty.. looks like they have a small piece of dirt .. 6 cylinder dirty injector and thats were the bearing went out at,, i think i have have like 2 or 3 dirty ones.. junk in them.. is there any way i could clean them, soak them,, ??? or just have to buy new ones..>> help.. my search isnt working.. i notified a moderator..im searching google now
Old 01-06-2009, 07:30 PM
  #64
ryanvv355's Avatar
Get a 5.3 and back the boost down to 6ish for now until you get bigger injectors and the tune nailed. You might consider putting rod bolts in your motor while it is out of the car so you can bump the boost up later.
What fuel pump are you running?
Old 01-06-2009, 11:04 PM
  #65
walbro or watever its called>>>255lph injectors were only like 83% if i remembered right..this 4.8 made 358whp 418wtq,, not bad completly stock with bad ,dirty injectors,, if the injectors went dirty it probly make more power.. owell.. to be continued
Old 01-07-2009, 01:03 PM
  #66
ryanvv355's Avatar
You may consider running a second pump just to be safe, the level of comfort on FI applications with that pump is around 475rwhp. Iknow your a ways off from that rwhp level but with a cammed 5.3 and 12lbs you will be close, plus with 1 pump working almost 100% duty cycle it will reduce its life, 2 pumps splitting the load will last longer and have no troubles supplying your engines fuel requirement. Send your injectors off to have them flowed out to 42ish lbs/hr that will kill 2 birds with one stone (fully clean and upgrade)
FI is a neighborhood where overkill in the fuel department is a good idea.
Old 01-07-2009, 03:05 PM
  #67
yea i already have them packaged.. im sending them to arizona... i told him to flow check them and only rebuild the one s that need it.. save some money.. i have deffintly thought about twin 255 pumps.. just need anothe 100 bucks and i'll do it..haha.. im still a teen and dont make enough money.. but im learning a/c so i can hopefully take over my dads business.. but unfounrtly bad timeing with economy.. owell.,, i def want to do twins 255 tho..
Old 01-07-2009, 07:39 PM
  #68
sorry had to rply it was on bad number..haha,, i think i found something to put in,, its aluminum too>>>
Old 01-07-2009, 09:05 PM
  #69
douglee25's Avatar
Well I can't say that I agree with everything you've done, but I sure as hell give you credit for trial and error and the learning process you're going through. That's the only way people did it back in the day. I give you madd props my friend. Looking forward to your new motor.
Doug
Old 01-07-2009, 10:06 PM
  #70
Doug
i try..haha..
i have another video.. no numbers;; my ehaust sounds horrible.. fare warning.. http://www.youtube.com/watch?v=v0a5DT66Zng
Old 01-10-2009, 06:08 PM
  #71
pics of the new motor.. i made some trades..and got it today!
Attached Thumbnails pics of my 6.0 swap to 70 chevelle-109_0172.jpg   pics of my 6.0 swap to 70 chevelle-109_0173.jpg   pics of my 6.0 swap to 70 chevelle-109_0174.jpg   pics of my 6.0 swap to 70 chevelle-109_0175.jpg
Old 01-10-2009, 08:21 PM
  #72
01 BERGER CAMARO SS's Avatar
sweet car bro
Old 01-11-2009, 08:43 PM
  #73
pics of the oil pan,that got fab up to fit,,fairly easy to do. i cut 3-4 inches of the bottom and got shop to welf bottom peaice on..cost about $60 to do..
Attached Thumbnails pics of my 6.0 swap to 70 chevelle-109_0178.jpg   pics of my 6.0 swap to 70 chevelle-109_0179.jpg   pics of my 6.0 swap to 70 chevelle-109_0180.jpg
Old 01-12-2009, 11:59 AM
  #74
BadAssChevy327's Avatar
sweet. nice progress. what year ls1 is that you just got? all this money in spare motors could have had the main one done lol.
Old 01-13-2009, 09:46 AM
  #75
hey chris,, its a 98',, i sold the main one.. cower rods,j.e pistons, 8 to 1 368ci..owell.. had too. no money.. hopefully i will be out there soon..
Old 01-13-2009, 12:05 PM
  #76
o damn, but yeah when money gets tight things happen. whered you get the 98 motor from, local?
Old 01-13-2009, 08:38 PM
  #77
trade with guy from jacksonville
Old 01-13-2009, 11:59 PM
  #78
supershift67's Avatar
How much oil does the pan hold now? I was thinking of cutting my pan also but I was worried it would not hold enough oil.
Old 01-14-2009, 09:18 AM
  #79
im gunna guess around 4- 5 qts.. but i also have two turbos..that takes some oil too.. and my pick up tube i just cut it shorter and put like a small chicken fence around it ,, to act like a screen.. but i just picked up a camaro pickup tube im gona see if that works.. but im not 100% it will
Old 01-15-2009, 05:44 PM
  #80
pick's of the pick up tube we made out of the truck one with copper pipes soldered togeather..took about 20-25 minutes to make
Attached Thumbnails pics of my 6.0 swap to 70 chevelle-109_0244.jpg   pics of my 6.0 swap to 70 chevelle-109_0245.jpg   pics of my 6.0 swap to 70 chevelle-109_0246.jpg   pics of my 6.0 swap to 70 chevelle-109_0247.jpg   pics of my 6.0 swap to 70 chevelle-109_0249.jpg
Quick Reply: pics of my 6.0 swap to 70 chevelle
