View Poll Results: Which are you using?
Drive by Wire
57
50.89%
Drive by Cable
55
49.11%
Voters: 112. You may not vote on this poll
Drive by Wire or cable?
Old Nov 28, 2008 | 11:17 AM
  #41
larrys project's Avatar
the below link is from another post, along with info on hooking up cruise control to an aftermarket switch. A little playing with your switch to learn which wires do what, & you should be in business. Hope this helps ya.
https://ls1tech.com/forums/conversio...questions.html
"Rostra Precision Controls" cruise control part # 250-3593. The following is based on my Speartech wire harness for a 2004 GMC p/u. John already had the cruise wires identified on the harness.
green wire from switch attaches to blue wire on harness (set)
yellow (resume/accell) to white wire on harness
brown (on/off) to grey wire on harness
red to 12V. (switched) with a 4 amp fuse
black to ground
pink (don't use)
blue (don't use).
The switch was about 35.00 from XXXX (am not sure if its OK to post the name & #). I can provide this info. but don't want to get in trouble. I talked to fellow at Rostra & he spit out the wiring info. faster than I could write. They were happy to help, & provided a distributers name & # on where to buy the switch.
Old Nov 28, 2008 | 08:29 PM
  #42
olsofti's Avatar
Thanks,Larry
I connected my switch to the c100 connector but it didn't work.
On my switch I have blue to +12
green to gray on/off
red to blue set
yellow to gray/black resume
I have verified that I have 12 volts going to the c100 connector at each of the wires when using the switch.
What am I doing wrong? Thanks
Ok, I didn't have the CMHSL connection.Wired it thru my tail lights works now.
Old Nov 29, 2008 | 06:32 PM
  #43
jfg455's Avatar
I've used both and they are each just as easy as the other. You can tune the DBW for excellent driveability and throttle response. G
