Cheapest wat to get a LS1
Old Aug 20, 2003 | 10:55 AM
Roadster18l's Avatar
Default Cheapest wat to get a LS1
Ok, Where is the best place to find a engine cheap? I want to do a LS1 Miata swap but it wont happen if I have to spend $3500 on a engine, computer, harness and trans. Did you get yours local or on the net? What should I spend or what did you pay? My dream is going if I can't get it in budget.
Old Aug 20, 2003 | 12:08 PM
88ls1blazer's Avatar
Default Re: Cheapest wat to get a LS1
i got mine local, the cheapest way is midnight auto, just make sure you reinforce the bed of the truck you pick it up with so it doesnt melt through
Old Aug 20, 2003 | 12:09 PM
Vents's Avatar
i can get you the parts to make an iron LS1 w/ 5.3 heads for 1300.
Old Aug 21, 2003 | 10:17 AM
Hey I resembled that remark about 10 years ago. Went to jail for it. Not to proud ot it today but learned my lesson. I will find one legal.
The Iron block is not in my plans. I know I am adding weight but I don't want it to get out of hand. My goal is power to weight ratio. I would like to keep the car around 2500LB.
I have found a long block for $300 with some of the sensors and the fueling. But I don't think it has the accessories or the harness. It also has a bent push rod. It may be more trouble than it is worth.
Old Aug 22, 2003 | 10:08 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Here is my take on the prices:
Engine: $500 - $2000
Computer: $100-150
Harness: $50 - $300 (for stock)
Trans: $750 - $1500
A longblock for $300 is a deal, I would probably myself pick it up just for spare parts. The heads alone are worth $200 - 300.
Old Aug 22, 2003 | 11:58 AM
30th TA 0219's Avatar
$3500 is what you are going to spend, no matter how you look at it. I would just pick it all up from the same person/car. There is a guy local to me right now with and LS1/T56 for $3500 as we speak.
Old Aug 22, 2003 | 12:38 PM
LS-1st-Gen's Avatar
Got my whole setup for 2500, (engine, trans, and PCM) from a salvage yard going by the name of Latino Salvage on the North side of Houston. I saw the smashed Z28 it came out of, so as far as I know my truck bed was in no danger of melting . The guy thought it was an LT1 by the way.
Gordon
Old Aug 23, 2003 | 02:10 PM
Rod G's Avatar
My 99LS1/4L60E (47,000 miles)harness and pcm they wanted $3,500 and after a little negotiating i left with it for $2,800
Old Aug 27, 2003 | 03:05 PM
Thanks guys I guess it is the going rate. Better deliver more pizza's to make this happen.
Old Aug 28, 2003 | 11:47 PM
CashDudeHomie's Avatar
Where is the LS1 for 300? If you don't want it I'll take it.
Old Aug 29, 2003 | 03:13 PM
99 Black Bird T/A's Avatar
Isn't that what the Rhino liner in the bed is for really parts ?
Old Aug 30, 2003 | 01:00 AM
ta12sec's Avatar
put me down for one
