Cut Harness-What is it missing
Old Jul 8, 2008 | 04:50 PM
NoClassic's Avatar
Default Cut Harness-What is it missing
The transmission portion of the harness has been cut just as it branches from the main loom. I know that the solenoid control plug, VSS, and two other trans plugs are missing. After reading some more and speaking with someone with more harness experience than I, it seems there is a possibility that I may need more plugs than previously mentioned.
What am I going to need to make this thing right.
Old Jul 8, 2008 | 09:23 PM
busta9876's Avatar
what kind of harness are we looking at here??? I've got a few 4L60E trans connectors kicking around with about 4-5 feet of wire on them, also o2 connectors, vss, etc...mostly from truck harnesses. If f-body i think the o2's are flat 4 pin..most trucks were square 4 pin.
good luck.
Old Jul 8, 2008 | 09:43 PM
NoClassic's Avatar
Its supposed to be from a 99 fbody.
I would be very interested in the trans harness section if you would be willing to let one go. I basically need everything in that leg of the harness if you happen to have it.
Old Jul 8, 2008 | 11:21 PM
Frost's Avatar
Fbody o2 connectors are square, 4 terminals, and the connector is gray.
I'll email you tomorrow Ryan, I'm on my phone right now.
Old Jul 9, 2008 | 07:28 PM
busta9876's Avatar
humm..not sure what all is on that bundle of wires for auto trans harness...
Looking at this M6 harness, the fron't o2's come out of harness near starter, and at front of drivers side head...i'm guessing the rear o2's run down the part going to the trans..not sure...
Old Jul 9, 2008 | 07:39 PM
Eddie 70's Avatar
Here is an 02 automatic harness. There is a post somewhere on here that has each connector labeled. Let me see if I can find it again.
Old Jul 9, 2008 | 07:43 PM
Eddie 70's Avatar
Here is the post I was thinking about with a picture that has the connectors labeled. But, it is for a manual car.
Old Jul 9, 2008 | 07:52 PM
NoClassic's Avatar
Great info Eddie. I think I pretty much figured out what I need.
4l60e main plug
Smaller trans plug(unsure of function just yet)
VSS
Drivers rear O2
