VVT-equipped L92 into my '89 Trans Am GTA (with pics)
#61
In the coolant passage, or what??
(I do NOT want to have to take this sucker apart at all, if there's any way around it...) Was it something that was obvious, or something that you discovered because you were tearing it down anyway?
And what do you mean by "oil tube"??? Thanks.
![Icon Neutral](https://ls1tech.com/forums/images/smilies2/icon_neutral.gif)
Mine has been stripped down to the short block because I'm having LS3 hollow intake valves installed. It would have been noticed when the valve covers were removed to change out the springs. (I'm not retaining the VVT system).
#63
1 Post
![Red face](https://ls1tech.com/forums/images/icons/icon11.gif)
Originally Posted by van454
Any progress to your car? Have you found another job yet mate?
To answer your questions, no, I haven't found a new job yet, although I've had about 4 telephone interviews in the last 10 days or so, which (in this climate) I'm finding somewhat encouraging. Thanks for asking.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
And I have indeed been making a bit of progress on the car, in fact the engine compartment (& a few other pieces!) should be painted either tomorrow or Saturday, & I'll post pics quite shortly thereafter.
Again, thanks. God willing there won't be any more extended delays...
#65
1 Post
Good to hear that things are still coming along with the car, hopefully you get a job soon so that you will have a little more disposable cash to spend on it.
Yesterday marked the second time that someone has told me that they'll help me with paint & then flaked out on me.
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
That's not to say that nothing's been happening with the car... THIS, ladies & germs, is what's frequently referred to as "mission creep", aka "while I'm here" disorder:
One of the things that I'd bought for this project is another quart of Chassis Saver paint, for use over rust. The plan was to remove all of the rust possible from the battery tray, where the SFCs are welded on, & a few other little areas, & then cover those areas with this paint. While I was under the car looking for any bit of rust that I could find, I noticed that there was a fair amount of aggressive-looking rust on the rearend, mostly on the center section (or "pumpkin"). I started to try to remove it with a wire brush on my drill, it didn't take too long to see that that wasn't going to be quick or easy to get to most of it. So I decided to drop the rearend. By myself. (NOT my most-brilliant moment...)
I had the center section supported by a large hydraulic jack, I'm wrestling with the last shock bolt, finally get it free, & what happens?? Yep - the rearend rotates forward, since the weight isn't distributed evenly. I reached out, caught it & held it, & started looking around for something to brace it with. Sucker was heavier than I'd remembered them being, my arm was telling me that it wasn't going to hold it forever, when I found a prybar that I could just reach & wedged it in. Lowered it down & started the rust removal. Here's the first picture, after a couple of hours of work with the wire brush attachment:
About that time, a buddy of mine came over, checked out what I'd done, helped me carry it outside, & asked one simple -but annoying- question - "Why aren't you using the sandblaster?" I had completely forgotten that he'd brought his sandblaster over here a few weeks earlier...
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Obviously, things went just a little bit more quickly thereafter. Here we have one good ol' Aussie 9-bolt, pretty much "in the buff":
Not having used one before, it was gratifying to see how quickly & easily it removed paint & rust from the rearend. NOT so gratifying was the discovery that it's also really good at getting sand in your ears, your socks, & other places where you would've sworn should've been safe from flying sand...
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
I wasn't able to work on it again for another day or two, but when I got back to it, I was able to put the good paint on it, & here's how it looked at the end of the night:
It's actually more glossy than I'd expected - when I'd painted the K-frame at the front of the car, that came out with a much more flat, subdued finish. (Not that I actually care either way, the protective qualities were the reason that I applied it...) I also applied that paint to the battery tray, the hole that I expanded for the intake tract, & the small holes that I cut in the firewall for the clutch master cylinder.
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
BIG thanks to my local F-bud Mike (DV8) who came over today & helped me bolt the rearend back into the car.
I'm still a fair bit annoyed that I still don't have the engine bay (& the other stuff) painted, but this is (more or less) a step in the right direction, albeit one that wasn't in the original plan. And for all I know, the body shop guy could've had some sudden issue come up, I'll wait until I talk with him before making a final judgment. (Biggest frustration is that we had beautiful weather here -in the mid-to-upper sixties!- last week, & it feels like we lost a really good "window" to get that done...)
One quick, & pretty much gratuitous note - this here is "shop cat":
As far as I can tell, she's a stray, but she's totally unimpressed by power tools - and the first time my compressor kicked on (NOT quiet), she just paused, watched it for a minute or so, & then continued on with what she was doing... Given how some cats can startle easily, I thought that it was pretty cool.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
So, I apologize that I don't have really pretty engine bay pics to show, but hopefully real soon. I have been able to get virtually all of the prep done under the hood, & just about everything else that I'm wanting to get painted is ready to go as well. And once that's done, I can make some real progress with getting everything bolted back together...
Will try for more updates soon.
#66
1 Post
I forgot to mention that I've set myself a deadline for getting the car on the road - and as of right now, I have just over 79 days & 14 hours before it gets here.
(This way, if it gets done by then I'll be able to put 500 "break-in miles" on the clutch, & still have all summer to enjoy the car.)![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
More ASAP.
More ASAP.
#67
I thought I had subscribed to this already. I like the 3rd gen swaps on here. I've got a black 89 gta with a rod knock. And I happen to have an ls1/t56 sitting on the floor. I'll probably thow it in the 89 depending on what I decide to do with my 67. I originally bought the ls1 for the 67 but now I'm wanting to build a big inch pontiac for it.
There's a few pics of my cars here
https://ls1tech.com/forums/introduct...ng-myself.html
#68
1 Post
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
And just on the off-chance that you haven't seen it, there's a LOT of good swap info (for the GTA) right here.
#69
Yeah I browse thirdgen.org once in a while too. I've read all the major swap threads over there. I liked ghettocruiser's black one before it was wrecked, but his blue one is looking pretty good. Do you have a thread over there too? Maybe that is where I subcribed, or maybe it was just a different car I'm thinking of.
I've been keeping an eye out for swap parts for my GTA. I've got pedals and 5 speed top for the console. There were some hawks swap headers and mounts on racingjunk.com pretty cheap but the guy never emailed me back about them.
#71
1 Post
And yeah, I remember seeing that ad on racingjunk & thinking "Man, someone's gonna get a good deal on that!!" If I'd had the money, I would've been really tempted...
Finally, yeah, I did create a swap thread on TGO, I just haven't had the time to update it as much as I'd like to...
Originally Posted by subtlez28
V8RUMBLE, did you see the latest issue of GM High Tech?
499hp L92 w/ VVT with a Comp Cam.
According to a recent Chevy High Performance I read, Billy Godbold of Comp Cams is pretty stoked about it too:
"With the cam phaser, you can advance or retard the cam centerline to the position it runs best at each rpm. That's cool, really cool. You can get a 60-plus horsepower gain, with no loss anywhere."
Hopefully soon though...
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
#73
1 Post
Thanks Van, with any luck I'll have new info on both fronts pretty soon...
Just looked to see if it was online, & sure enough, it is... ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Geez, I can't wait to start modding this bad boy...!
Match one of those cams up w/ a pair of CNC'd heads with lighter valves...
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
(I also like the little 'dig' that they get in at FAST for not having an intake manifold for the L92 heads - you think that maybe they were a little frustrated at being so close to 500, & just not getting the last little bit of air?)![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Good article J, thanks!
When we ran the larger of the two cams it was apparent that the VVT takes away the "peakiness" of a big cam, allowing heavy breathing at the top end with little penalty in the lower rpm.
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
#74
Also kinda interesting that they said the truck manifold had a performance advantage. Too bad it is so tall, and hard to package in a car. I wonder if it will fit under my buick's hood.
#79
1 Post
Crap, there's a problem with the paint that I didn't anticipate...
It looks too freakin' good, when I lift the hood it's going to make the rest of the car look bad!!!
