84 ss 6.0/mp122 and 4l80e swap
Hey guys am finally starting my 6.0l swap on my 84 montecarlo ss.
I got brp headers,mounts,oil pan,gn gas tank,and fuel sending unit.
what size single intank fuel pump would you recomend for a magnacharger mp122 on 6.0l with a 2.9 pulley?I will be pushing max 15lbs of boost.
I have the Spectre (SP) Industries EFI A-body tank in my car, the one BRP sells. It has been determined the pump in tank is similar to a Walbro 255 as far as performance. I am going to run that for now with 42lbs injectors on low boost, 5-6 psi. IMHO the 255 is too small for my application to keep me feeling warm an fuzzy inside. I would recommend a Bosch 044 pump swap in your tank and running a 60ish lbs injector to keep everything happy. When I crank the boost up I plan on running a Weldon D2015-A pump inline and 60's.
